LSi15 --> DB840 upgrade
Doing it next weekend...
Amazon has them for 39.44 each & ships free for anyone thinking of pulling the trigger.
The upgrade isn't earth-shaking, but it's well worth doing...especially at this price.Things work out best for those who make the best of the way things work out.-John Wooden
Thanks.. just got a price adjustment.
Dan
We did it on our first set of Lsi15's.
I guess to explain it quickly, it reduces the boominess of the upper bass a decent bit.
The rest of the bass honestly sounds pretty much identical.
But we found with our 2nd set of Lsi15's different placement yielded a somewhat similar sound.
Seems the Lsi15 do not like being close to corners at all. On our 2nd set, they are on a very wide wall about 7 foot from any corner and the boomy issue is totally gone. -
There's a thread on here somewhere about this upgrade. General consensus was it was worth it, not a HUGE improvement, but really smoothed things out. I'd post a link, but I'll get lost/sidetracked, and wind up looking at cat videos (which, of course isn't a bad thing, but ....)
One of the commenters on the Amazon page, "Faradave" posted a pic of his use of a "couple" of DB840's.
I could be wrong (as IF !), but I think this might be drifting a little bit into the area of "Overkill".
..... unless you're having "The Who" stop by for a BBQ and impromptu jam session in your backyard coliseum.
96 DB40's. You'd probably want to check on the noise ordinances of your HOA before proceeding.
TL:/DR good upgrade. Post some pics when you're done.
Sal Palooza -
Grabbed a pair even though my LSi15s are for sale."Some people find it easier to be conceited rather than correct."
"Unwad those panties and have a good time man. We're all here to help each other, no matter how it might appear." DSkip -
I'm sure you know this already, but be sure to REMOVE the stock rubber gasket around it. It doesnt fit with it, and it would look horrible if it did. Use Armacell on the inner baffle and on the back of the driver and your golden.
I'd also rotate the sub so you are NOT using the same holes as the original drivers to ensure better grip with the screws."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
To me...it didn't necessarily add any output, but just made the speaker more coherent as a whole.
I loved my 15's and even more after the upgrade.
Not life changing, but well worth it.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
This is very true even with the upgrade. Another things to do is seal the hole where the wires pass through to the upper section. I have heard of other Dynamatting the port tube but I haven't tried this yet.Stan
Main 2ch:
HT:
Other stuff:
Thanks for the tips. I enjoy the lsi15s but feel the bottom end tends to loosen up a bit. This upgrade looks like it will alleviate the issue.
How long for them to break in about?
looking to get the LSiM 705 in the future. from what i read they seem to be heads and shoulders over the LSi15s. -
My opinion only....
The 705 is a better speaker than the 15's.
However, when I stepped up from the Monitor 70's to the LSi15's...I went slackjawed. I still remember the moment to this day. For weeks, I would have the feeling at work that I just couldn't wait to get home to listen to music.
When I went from the LSi15's to the LSiM705's, I was disappointed. Not disappointed in that the 705's were a bad speaker, but in the fact that I was expecting the same jaw-dropping feeling from upgrading, which I didn't.
So part of this is just my inexperience and expectations, and I must reiterate...THE 705 IS THE BETTER SPEAKER. Simply, I just personally wouldn't say 'head and shoulders' better. The 15 is a damn good speaker too.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
Pretty much my thoughts, but I did feel as though there was tad more output and the bass was a bit tighter.Things work out best for those who make the best of the way things work out.-John Wooden -
Is Armacell recommended over Moretite?
Yes, more for ease of install/uninstall purposes than anything to do with sound quality, etc."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
EndersShadow wrote: »
What size and length of Armacell is recommended? Thanks again. -
I just bought a roll of it at Home Depot and put it on the opening and the speaker and then trimmed the excess off. I'm not sure they have different widths or lengths.
A single roll would be all you need and then some."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
You don’t need to use goo to make a new gasket. The db woofers come with a rubber gasket. Remove it and cut it in half so you have a flatter thinner gasket. You’ll also need to cut out a small portion of the gasket so that it fits in the smaller opening. I cut it once and removed the portion that overlapped. Not sure if I’m explaining wellbut I did this for both woofers and it worked or great
I'm going to be putting a pair of DB840's up for sale presently. If someone is interested in a pair, please PM me.
