Monitor 10A speakers, mine at last!
124»
  • lawdogg
    lawdogg Posts: 469
    Yes looks great!
    <3 my 3.1TLs
    I will fix your shifted magnets for free. :)
  • keck
    keck Posts: 39
    Thanks. I have some stains of the PowerGrab on the magnet. How can i removed it? Do i need to do it?
  • teekay0007
    teekay0007 Posts: 2,288
    keck wrote: »
    First, you'll need the proper equipment: a crowbar, a bolt cutter and a full set of well-lubed, 30-weight ball bearings. Oh, and one can of ripe black olives.
    J/K :p You're doing just fine.
    Report back on how they sound, post upgrade/mod.
  • keck
    keck Posts: 39
    Dear all, i need advise on which amp i should buy? Should i.....
    1) Buy 2x Rotel RB970BX MKII @$300 (Run as Mono block)
    2) Just buy a RB960BX @$80
    3) Save $$ to buy a higher pwer amp.
    Which one do you all suggest?
    My current setup:
    1) Azur 651C
    2) GDA600 or MSB Link
    3) B&K Reference 5 Series 2
    4) Adcom GFA 535II
    5)SDA 2B
