Playing around with speaker cables
VR3
VR3 Posts: 29,535
Eichmann bayonet banana plugs
Supra Quadrax wire
Furez cable splitter
Neutrik NL4
Black tech flex
Very tedious
    F1nut Posts: 51,944
    Indeed. I don't think think a lot of folks consider the labor time/cost when complaining about the cost of better cables.
  • vmaxer
    vmaxer Posts: 5,120
    Very nice.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    VR3 Posts: 29,535
    edited March 2017
    Absolutely agree, 1000000%!
    Thanks guys :)
  • F1nut wrote: »
    As quoted above I agree to a whole bunch of percentage points. The fit and finish of cables from even the midrange guys does not change from the lowest offerings to their highest.
    Signal Cable is a prime example. No matter what you pick from their options the quality of workmanship is the same. Cheap wire and ends to expensive wire and ends takes the same effort to do well.
    mhardy6647 Posts: 35,200
    Like the craze some years back (probably pushing 20 years ago, now) for braiding CAT5 to make speaker cables.
    VR3 Posts: 29,535
    there.. just isn't a way that's happening
    pitdogg2 Posts: 27,233
    1976doc wrote: »
    Did that work? Was it worth the effort?
    It works but it is a ton of work for mediocre at best cables. I have done it several different ways and never was satisfied with the results. Cheap good cables run circles around data wire with a ton less work.
  • motorstereo
    motorstereo Posts: 2,359
    I've been playing around with speaker cables myself lately........these came in last week and I'm liking what I'm hearingbdnlil3sml9e.jpg
    edited March 2017
    1976doc wrote: »
    Oh, it wasn't me! :-)
    I used a simpler CAT5 cables for some time -- it's better sounding than zip cord (recall that my reference point is single-ended, direct-heated triode amps with no global negative feedback, i.e., fairly high output impedance)... but almost any "good" speaker cable will outperform the stuff.
    I'm currently using some Canare cabling I got from ALL212 right here on the Polk forums.
    (I'm not big on high-zoot wires, myself -- if I had just loose stacks of money cluttering up the house, I'd feel differently, though)
    In the interest of disclosure, though -- I do have some bits of CAT5 wiring still in the 'real' hifi upstairs... the innards of the Duplexes are wired with it, as are my supertweeters.
  • helipilotdoug
    helipilotdoug Posts: 1,230
    Yep2 wrote: »
    Very Nice!
    I like those splitters. B)
    We have those splitters in several configurations. They really do dress the end of the cable and make it look better than just heat shrink.
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
