Playing around with speaker cables
VR3
Eichmann bayonet banana plugs
Supra Quadrax wire
Furez cable splitter
Neutrik NL4
Black tech flex
Very tedious
Supra Quadrax wire
Neutrik NL4
Black tech flex
Very tedious
Indeed. I don't think think a lot of folks consider the labor time/cost when complaining about the cost of better cables.Political Correctness'.........defined
President of Club Polk -
Very nice.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Absolutely agree, 1000000%!
Thanks guys
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
As quoted above I agree to a whole bunch of percentage points. The fit and finish of cables from even the midrange guys does not change from the lowest offerings to their highest.
Signal Cable is a prime example. No matter what you pick from their options the quality of workmanship is the same. Cheap wire and ends to expensive wire and ends takes the same effort to do well. -
Like the craze some years back (probably pushing 20 years ago, now) for braiding CAT5 to make speaker cables.
there.. just isn't a way that's happening- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Did that work? Was it worth the effort?
It works but it is a ton of work for mediocre at best cables. I have done it several different ways and never was satisfied with the results. Cheap good cables run circles around data wire with a ton less work. -
I've been playing around with speaker cables myself lately........these came in last week and I'm liking what I'm hearing
Oh, it wasn't me! :-)
I used a simpler CAT5 cables for some time -- it's better sounding than zip cord (recall that my reference point is single-ended, direct-heated triode amps with no global negative feedback, i.e., fairly high output impedance)... but almost any "good" speaker cable will outperform the stuff.
I'm currently using some Canare cabling I got from ALL212 right here on the Polk forums.
(I'm not big on high-zoot wires, myself -- if I had just loose stacks of money cluttering up the house, I'd feel differently, though)
In the interest of disclosure, though -- I do have some bits of CAT5 wiring still in the 'real' hifi upstairs... the innards of the Duplexes are wired with it, as are my supertweeters. -
We have those splitters in several configurations. They really do dress the end of the cable and make it look better than just heat shrink.Very Nice!
I like those splitters.
Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com
