Anyone use different output levels for different sources?
This ^^^^^^^
Give the man a cookie.
lsi 9's -
From what little I can gather the op is talking about a trim level function so he can set each source's level individually where they will stay once adjusted. I'm doubting your Onkyo receiver has that function.
Trim levels are for balancing out the sound in a given room, not necessarily volume. Different sources will always sound different for various reasons, different impedance, cabling, etc. The volume control compensates for line voltage, which is why F1NUT suggested simply using it.
When you try to make all sources sound the same volume wise by trim level adjustments, some are not going to sound so good. You sacrifice sound quality in one source for the benefit of equal volume. Using the volume control to compensate is the easiest way without sacrificing sound quality, and guess what ? Every AVR comes with a remote so it doesn't get any easier.HT SYSTEM-
lsi 9's -
This is just the case of someone who doesn't understand how to setup a system and is trying to learn how.
After sifting through all the bull crap I figured out what dude is trying to talk about.
My advise would be to do the following.
Setup your home theater system exactly how it should be.
If you like Audyssey then by all means use it. If you find most of your sources don't sound quite right? Well I'm here to tell you to recalibrate without that smack. I hate Audyssey as I think it does more harm then good. I prefer to calibrate my systems manually. If you don't know how to properly calibrate a system , do some research and learn.
The key is 75DB to all speakers. If your advanced you can slightly tweak from there but usually in most rooms that works great.
As for leveling out sources, some preamps and receivers have input level adjustments. You don't re adjust output levels as thats just mental.
Adjust each input source to the desired level or use a SPL meter to get each source close to the same level.
Sources are going to sound different due to recording quality, Source quality and transfer cable quality.Dan
Guys, I think everyone is missis it. Below is the best explanation to be found. Listen to all of it, may take a few complete listens but the answer is there. It is a classic.
Let me know your thoughts please.
The lay ear may have problems though.
https://m.youtube.com/watch?v=2fjcJp_Nwvk
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
So -- I'll throw caution to the wind
and mention here that, in the olden (analog/stereo) days, many "full functioned" (over-functioned!) pre-amps, and some other components, would include trimmer pots for the various inputs to normalize levels when switching from component to component.
The McIntosh preamps of the 1960s and 70s are classic examples -- for all I know, they may still offer such gizmos for their clientele. It's the kind of thing that Mac purchasers seem to like. That and huuuuuuge blue meters and colored LEDs to light up their vacuum tubes. OK, but that's another troll for another day
Anyway, anyway, anyway -- one may see the trimmers towards the top of the frame in this photo of a Mac C28 preamp.
C-28 innards by Mark Hardy, on Flickr
Heathkit's component kits also tended to have level trimmers; the AR-29 receiver is an example that springs to mind.
AR-29 by Mark Hardy, on Flickr -
The OP has a Denon I have a Denon in the secondary HT its rather easy to adjust settings in each source. I ran the calibration and tweaked the other settings manually such as in CD, source, Tuner, Phono, etc etc, its not to complicated. The OP states he does not use tone controls, so basicly, for the solution to his problem the volume control on the remote is his solution no reason to make it difficult when it really is not.Home Theater
I like the way you talk, you sound like a race car motor.
I have a Denon X4100 AVR. I have my Xbox set to be 12db lower than my U-verse. That way when I switch inputs the volume is the same or close enough between the two.
Otherwise my XBOX One at 50 is much louder than my U-verse, hence that setting being used. I found it tends to just be just thbXbox One with that issue. I don't have the same problem with my Squeezebox classic."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
I never realized that was part of an automatic transmission. I have always owned a manual, but if my next car does offer both a trifibulator and diktarobitron in its transmission then I will finally buy one. Thanks. Learn something everyday.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
of course, that was back from the days when automatics were simple == "D" and "L".
Nowadays, whoo-boy! I recommend the Fiat-Chrysler nine-speeds. Sooooo many more things to go wrong with them, and packed chock full of the vaunted Fiat-Chrysler engineering, materials sciences, and quality control expertise. Only 10% or so spit flaming parts out onto the pavement as new owners drive their vehicles off the dealers' lots, as I understand it.
PS -- that was excellent. I understand automatic transmissions a bit better now.
Back in the 70s my sister wanted a good stereo so I told her to buy a HK receiver, AR turntable, Shure cartridge, and Advent speakers. In those days Radio Shack ICs and speaker wire were used. Anyways, it sounded great.Lumin X1 file player, Westminster Labs interconnect cable
I'll never buy a vehicle with an auto transmission, stick shift for life.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
I will always have at least one manual in the stable if possible.
It makes cars more interesting & just plain more fun to drive. 95 hp and a manual transmission is more fun than 400 hp and auto. OK, I don't really know that
but I do believe it.
They (manual transmissions) get harder & harder to find, though in new cars. The only one we have at the moment is my '01 Toyota Taco[ma].
Even today, a manual transmission is one of the best forms of vehicle theft protection available. Soon it'll be the best.
Oops. Wrong thread.
Automatic trannies are way beyond what they once were. A great many have the option to manually shift.....a total blast.
President of Club Polk -
But no clutch, right? -- it's all about the coordination
Obviously, just my perspective, but, heck, I listen to records & tapes and use - and abuse - vacuum tubes.
It's just not the same, I hear you though.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
One one? Sounds like you had one already.
Depending on the day of the week I will use different input levels depending on the source.Lumin X1 file player, Westminster Labs interconnect cable
Easy to say when you live in BFE
Live where there is traffic, auto Tran becomes a must
Anybody notice the OP has disappeared?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
txcoastal1 wrote: »
I lived in Denver for several years. Still wouldn't have traded it for an auto.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
I use a manual in San Jose on 101 during rush hour with no problem. It keeps me alert, and on top of things. When it takes 45 minutes to go 12 miles there is a lot of clutch use.Lumin X1 file player, Westminster Labs interconnect cable
Automatics are just so uninspiring to drive to me. Plus a manual loses less power than an auto so more power to the wheels less lost to heat, better MPG, and as a broad generality more reliable.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
The only time I regretted having a manual was in the late 90s when I had left knee surgery, and couldn't bend my leg for a few weeks. I had to put the seat all the way back, and stiff leg the clutch. The car jumped around like a student driver was at the wheel. LOL.Lumin X1 file player, Westminster Labs interconnect cable
Same in Chicago pal, and clutches wear out, cost money. Not for big metro areas in my view. Unless it's those auto trannies that have shift paddles on the steering wheel that work like a manual.....those are a blast.HT SYSTEM-
lsi 9's -
I bought my car in October 2004 as a 2005 Mazda 3S. Still on the original clutch, although that is in the back of the mind as a future expense.Lumin X1 file player, Westminster Labs interconnect cable
I dunno, the MPG difference isn't that big anymore and as far as more reliable.....how about when that clutch starts to slip. Just one more thing to spend money on. I guess it depends on the type of car, nobody wants a race car that's an automatic. Nobody wants a grocery getter that's a stick shift, right ?
......and nobody wants to be stuck in stop and go traffic for 2 hours with a manual tranny, regardless of the type of car.
