How much batting in RTA 12B's
Michael8it
Looking for some opinions on how much batting to use in my overhaul of RTA 12B's.
Thanks,
Thanks,
Carver C-1, M-500 MKII, Yamaha HTR-5835, Polk RTA 12BM's (M-for mod'd).
If you have the dacron that was originally in them, just use that. Make sure it is above the passive radiator
I don't. The cabinets came from original RTA 12's and had a foam wedge and no polyfill. If I understand the concept, you want polyfill from just below the drivers (middle of the cabinet) to the top, and none behind the PR. Correct?Carver C-1, M-500 MKII, Yamaha HTR-5835, Polk RTA 12BM's (M-for mod'd).
That is correct
I think your 12s should be similar to my 2Bs. You might find this thread useful: How much polyfill for my 2Bs?Michael8it wrote: »I don't. The cabinets came from original RTA 12's and had a foam wedge and no polyfill. If I understand the concept, you want polyfill from just below the drivers (middle of the cabinet) to the top, and none behind the PR. Correct?
- SDA 2BTL · Sonicaps · Mills resistors · RDO-198s · New gaskets · H-nuts · Erse inductors · BH5 · Dynamat
- Crossover upgrades by westmassguy
- Marantz 1504 AVR (front speaker pre-outs to Adcom 555)
- Adcom GFA-555 amp · Upgrades & speaker protection added by OldmanSRS
- Pioneer DV-610AV DVD/CD player
- SDA CRS+ · Hidden away in the closet
Glad to see another pair of RTA-12x being resurrected. I did the full Monty on my 12C's, except for the RD0194's and am very pleased with the performance improvement."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
