Tube buffers
    pitdogg2 Posts: 26,961
    no not peel skin hot but i don't wish to touch them after some hours on:)
    yes in agreement with the other tubes putting the 3rd degree factor in motion.
  • mikeyb128
    mikeyb128 Posts: 2,885
    Willow wrote: »
    mikeyb128 wrote: »
    I would save the cash and put it toward a tube pre with home theater bypass. I think the result will be much more rewarding.
    I'm thinking this might be the way.
    A tube pre will elevate your musical enjoyment to another level. And you can get a really good one in the 1000 (cad) and under category. I used a marantz ht processor as a 2 channel pre and worked pretty decent. But a dedicated 2 channel pre will have you asking yourself why you didn't do it sooner.
    2 channel:
    Theater:
  • Nightfall
    Nightfall Posts: 10,084
    mikeyb128 wrote: »
    *cough* @nbrowser *cough* o:)
    afterburnt wrote: »
    Village Idiot of Club Polk
    tonyb Posts: 33,068
    mikeyb128 wrote: »
    Willow wrote: »
    mikeyb128 wrote: »
    This ^^^^^
    mhardy6647 Posts: 34,930
    Always use the right tool for the job.
  • Willow
    Willow Posts: 11,218
    Easier said than done when trying to accommodate TV hooked up to it too.
  • mikeyb128
    Willow wrote: »
    Home theater bypass. Let's you use the receiver as well. So actually quite easy :smiley:
    2 channel:
    Theater:
  • Willow
    mikeyb128 wrote: »
    Willow wrote: »
    Well you have my attention. Which are good and not very expensive?
    tonyb Posts: 33,068
    Willow wrote: »
    Not really, as already stated....one with a HT bypass is your ticket. You can even use one without the bypass, as long as it had a standby mode so you don't have to leave the tubed pre on all the time.
    Which ones are good/bad/cheap ? Depends on your idea of cheap, throw out a number to stay under. Tons of options new and used out there.
  • Willow
    My problem is not as bad as I thought speakers are now farther from the back wall and with my tt the sound is deep and wide and full and very rich.
    tonyb Posts: 33,068
    Hmmm....deep/wide, full....very rich ? Sounds like the girl of my dreams. :)
    So -- you're a vacuum tube woman fan, then, I take it?
    speaking of tube buffers (not that anyone has been lately, it seems)...
    I am, it goes without saying, very biased -- but I still would encourage anyone interested in these little boxes to take a look at this threadful of grouchy old white men (myself included) pontificating on them. :)
    https://www.audioasylum.com/audio/general/messages/72/725610.html
  • FTGV
    FTGV Posts: 3,650
    Tube buffers...meh.I suppose the injection of some even order distortion can make an overly clinical sounding system a little more warm and fuzzy. The added distortion and probable deteriorated noise floor might be akin to putting lipstick on a pig.YMMV.
