Please recommend a good CD clock radio
pglbook
in Electronics
My old CD/radio/alarm clock died and I am in the market for a new one. The one I had was a rather cheap unit and I am looking to upgrade to one that has excellent sound. I want mainly to play CDs at night. I don't need a radio but it's ok if it has one. Can someone recommend one with excellent sound? I know many here are not fans of Bose but the Bose Wave actually gets great reviews but it is very expensive. I'd appreciate any suggestions. Thank you,
For what it does, the Bose Wave will be good enough for you.
I own a few sets of Bose speakers. -
Thanks, lightman. The Bose Wave seems to be excellent but I do not think I want to pay $500 for it. That seems like a lot of money to pay for a CD/clock radio. Heck, I paid less money for my Polk SDA 2BTL speakers and also paid less for my Parasound amp (both bought used, and I know the Bose Wave is a new item, but $500 still seems like a lot of change for the Bose Wave). Any other suggestions, at a lower price point than the Bose Wave? Thanks.
Does it have to be a CD player? I mean you can get an older iPod or other MP3 player and a nice little pair of power monitors for a lot less.
Another option is a squeezebox boom on eBay for about $150. Built in wireless and access to tons on internet radio stations. And if u have a computer with music downloaded, you can download the Logitech software and stream your library. Or pay $10 a month for Spotify and stream directly from mysqueezebox.com, no computer necessary. That's the route I would go personally.
There just aren't really any quality cd alarm clock radios to compete with Bose, because, well no one wants one...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer -
Check out Tivoli Audio, much better than Bose IMHO. https://www.tivoliaudio.com/shopIf you can't hear a difference, don't waste your money.
Those look cool, but same basic problem as the CD player version is $600. Dump the CD player and the options really open up at a lower price.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
lsi 9's -
Thanks for the feedback. A CD player is a must as I still have a ton of CDs. I know I can download the music to my computer, stream it, etc...and I do have a Polk Camden Bluetooth wireless speaker....but I am looking for a good sounding CD/clock radio at a price point of under $250.
Thanks, tonyb. I know I can get a used earlier Bose Wave model in my price range. They are up to the Bose Wave IV model so the first 2 Bose Wave models are relatively inexpensive on the used market (i.e., less than half of what the new Bose Wave IV costs). Does anyone know the difference between the different Bose Wave models (Bose Wave I-IV) and if either the Bose Wave I or II would be worth getting at around $150-$175, which seems to be the average going price for those 2 models used.
Gonna be hard to get a good sounding unit for 250, new anyway. Cruise your local Craigslist, maybe something will pop.HT SYSTEM-
lsi 9's -
If Tivoli still makes one, that's the way to go, I'd opine.
Next best would be Sangean; do they make one?
I like the Sangean radios; we have one in our kitchen that sounds good (very good, actually) and is a very "hot" radio; It will pick up WBZ-AM in Boston (120 miles away) day or night -- as long as I turn the LED lights in the kitchen off
Think of the Sangeans as "Tivoli Lite". The Tivoli products are a notch nicer overall -- but they're also significantly 'spensiver.
All this being said:
CD players are sort of -- Twentieth Century, though.
Of course, the other option is a clock radio with an AUX input. Hook a "Discman" player to it (remember those?) and use the sleep timer on the radio if so equipped. The radio alarm will (should) still work in the morning -- although I guess the CD player would have to be set to repeat play(?).
The other option would involve a receiver, CD player and system timer. Achievable but a bit of overkill
EDIT: In total seriousness, if the OP decides to go the "AUX in" route, I'd be happy to chip in a "Discman" type player. I have -- a few -- "in stock"
mhardy6647 wrote: »EDIT: In total seriousness, if the OP decides to go the "AUX in" route, I'd be happy to chip in a "Discman" type player. I have -- a few -- "in stock"
I'd take him up on this kind offer and get a squeezebox boom I mentioned. It has an auxiliary input. Or there are many other similar options...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
-- I assume the OP wants some kind of way to listen to a CD as he (or she) drifts off into the arms of Morpheus, but will still jangle him (or her) awake when needed in the morning
If the 'boom' will do that, then -- yeah, that'll work.
At any rate, there really are a handful of little portable CD thingies here, so I could easily chip one in. The only restriction is the OP's gotta be in the contiguous US (for shipping) -
Squeezebox boom has a alarm that can wake you up with music or with an alarm tone.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
https://quadcities.craigslist.org/ele/5986177199.html
Get you one of these instead $5 and wake yourself up to tunes from the bedroom rig everyone has a bedroom rig right?Home Theater
Polk Audio Boom Swimmer, Polk Audio Urchin -
Get a pioneer timer dt 530 or 550 and skip's Ifi50Musical Fidelity Tri-Vista 300, Audioquest Thunderbird Zero Speaker Cable, Tyler Highland H2, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
Hey Pete, good to hear from ya don't have any advise for ya except I always wanted a Tivoli Model one! no CD though but they do have one.2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
So are alarm clocks
Couple of choices below from Amazon with good reviews generally. Not cheap, but also not as expensive as a Bose. There's not much in this market anymore of quality, and Bose knows it.
https://www.amazon.com/Yamaha-TSX-B235BL-Desktop-Audio-Bluetooth/dp/B010FH2S3O/ref=sr_1_31?ie=UTF8&qid=1488587674&sr=8-31&keywords=cd+clock+radio
https://www.amazon.com/Pioneer-X-CM56B-Stereo-System-Bluetooth/dp/B01KU4AJ06/ref=sr_1_35?rps=1&ie=UTF8&qid=1488587748&sr=8-35&keywords=cd+clock+radio&refinements=p_85:2470955011 -
I strongly recommend
https://www.amazon.com/HELLO-KT2053-Stereo-Loading-Player/dp/B0015ESWHI/ref=sr_1_1?ie=UTF8&qid=1488588606&sr=8-1&keywords=hello+kitty+clock+radio+cd+player
My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
That could be modded with some black paint.
So are alarm clocks
There is that. -
I found some along with some camouflage paint bought it and now can't find any of it.My New Year's resolution is 3840 × 2160
What's a clock radio? Is that an app I can download for my phone?
Mikey081057 wrote: »I found some along with some camouflage paint bought it and now can't find any of it.
I put some spot remover on my dog. Now he's gone.
I loved his stand up...back in the day.
me, too.
I love how these threads evolve. Or in some cases, devolve. You never know where they will end up, if commented on enough.
What was the original question now?
Maybe a discontinued item, nobody has them in stock.
His other cheap choice is a cd/boombox.....some have alarms build in and are smaller in form factor.HT SYSTEM-
