Ceiling treatment - clouds. What a pain.
2
  • BlueFox
    BlueFox Posts: 15,250
    Nice work, but might be overkill. Just try it with the center two panels and see how it sounds.
  • It looks good Joey! The only thing that I would have done different was use wire cable instead of chains. I went to flying all speakers in installs with cables years ago due to a cleaner look. polarfocus.com/catalog/genus/wire-rope-products-7/
  • WagnerRC
    WagnerRC Posts: 2,219
    Very nice job. very professional looking.
  • Joey_V
    Joey_V Posts: 8,603
    Wow that's a good one... now do I redo it and go through the pain.... ??
    mhardy6647 Posts: 35,376
    kharp1 wrote: »
    On a serious note, great thread Joey. I appreciate the pics and descriptions of your work. Been contemplating ceiling treatments and wondering what all was involved.
    Yes, in all seriousness, it is a cool thread documenting some very nice work.
  • Joey_V
    Joey_V Posts: 8,603
    BlueFox wrote: »
    I did, not enough, image still pulled up.
  • Joey_V
    Joey_V Posts: 8,603
    edited February 2017
    kharp1 wrote: »
    Hopefully this can help someone looking to do the same thing.
    Advice:
    1. Measure 3 times, hang once.
    2. Toggle hooks rock.
  • vcwatkins
    vcwatkins Posts: 1,992
    Fantastic job. *I* never would have attempted such a tight grouping since any errors are easily apparent. I think that's what makes your install look so good. Well done.
    Now, time to enjoy those new Pioneer speakers. Or did I get that wrong?
  • Joey_V
    Joey_V Posts: 8,603
    vcwatkins wrote: »
    Re the tight tile look, it was not as bad as I thought, once you precisely mark the hook drill coordinates, I just used painters tape that was 1" wide, and stuck 2 of them next to each other to make sure the next panel was 2" from the adjacent one. But I agree, it was a pain to get it all centered and lined up right.
    Re the Pioneer speakers... hahaha... funny you mention that.... I was this || close to buying those Pioneer speakers.
    Ala TAD Reference 1s...
    Unimaginably close.
  • I also found the white spray paint hides chain and hardware against a white ceiling nicely.
    Did you notice any dB crop in ambient noise? I get 2-3 dB drop just having carpet in my listening room over the tile in my living room.
  • Joey_V
    Joey_V Posts: 8,603
    Hi Dennis,
    I would have to check if I have a dB drop. The ceiling is grey... I really like the wire idea from above...
  • I've gotten to where I paint all hardware anymore. Grey, white or beige spray paint is in my installation kit at all times. From a few feet back it just disappears. This is really true of black speaker cabling.
  • vmaxer
    vmaxer Posts: 5,121
    Cept' you still can't get black paint. :'(
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    vmaxer wrote: »
    Maybe he's got, you know, a pro resource :*
    He could tell us, but then he'd have to kill us.
  • vcwatkins
    Joey_V wrote: »
  • Joey_V
    Joey_V Posts: 8,603
    vcwatkins wrote: »
    Joey_V wrote: »
    It's true. Emma was there with me twice and the wife gave the OK.
    It was a local seller and he was running pass xs300 monoblocks.
  • sgmsmg
    sgmsmg Posts: 556
    Excellent job Joey! Another well detailed project. Glad it worked out and had the results you were looking for.
    Pre: Bryston BR20
    Amp: Buckeye NCx500
    Speakers: Polk L200
    Source: Oppo UDP-205, Bryston BDP-3, Bryston BCD-3, Apple TV, Amazon Fire
    Cables: Wireworld Gold Eclipse 7 Speaker, Wireworld Gold Eclipse 7 XLR, AQ Diamond USB/HDMI
    Power: PS Audio P10 Regenerator, AC12, AC10 and AC5 Cables
    Display: Sony XBR65Z9F
    Pre: Anthem AVM90
    Amps: Buckeye NC502
    Speakers: Polk LSiM 707 (FL/FR), Polk LSiM706 (Center), LSiM 703 (SL/SR/SBL/SBR), Polk 900-LS (Atmos)
    Subwoofers: SVS SB16 x 4
    Source: Oppo UDP-205, Apple TV, Amazon Fire
    Cables: AQ Meteor/Rocket 88, AQ Niagara/Sky
    Power: Torus AVR20, Shunyata Denali, Shunyata Delta, Cullen, PangeaAC9SE Cables
    Display: Sony XBR85Z9G
  • vcwatkins
    Joey_V wrote: »
    Well that backfired, hehe. This is what I had in mind when I wrote that - trying to goad you into the reveal. :)
  • Joey_V
    Joey_V Posts: 8,603
    vcwatkins wrote: »
    Joey_V wrote: »
    Hahah... don't worry, I didnt get the TAD Ref 1.
    I was pretty close, but I walked away in the end. My room is just not big enough to accommodate such a beast.
    Also, it was kind of expensive.
  • JuanR
    JuanR Posts: 718
    Joey I just bought a Joule LA-150 and man does this Joule sound fantastic...I am still interested in your comparison between the Cary 05 and the McIntosh, I plan on getting either one of those a few months down the line...
    Nice job with the ceiling panels!
    Juan
  • Joey_V
    Joey_V Posts: 8,603
    JuanR wrote: »
    Juan
    Good to hear! I have not experienced the Joule but I am sure that's good
  • WLDock
    WLDock Posts: 3,073
    vcwatkins wrote: »
    LOL! That would be something....
    What if he got some Sony speakers? LOL! However, I'm not sure who would pay $27,000 for Sony speakers? I guess the same guy interested in the $29K Pioneer / TAD speakers?
    Anyway, man are the Sony SS-AR1 nice sounding speakers.
    http://www.soundandvision.com/images/Sony-SS-AR1.jpg
    http://www.stereophile.com/content/sony-ss-ar1-loudspeaker#1eCQ2E4BiowOCB8g.97
    Anyway, Great job on the overheads Joey!
    Someday, I want to put some funky and artsy treatments on my walls and ceiling.
    https://s-media-cache-ak0.pinimg.com/originals/45/b8/21/45b82136b9b5427fb40c947e9deceeb1.jpg
    http://scontent.cdninstagram.com/t51.2885-15/s480x480/e35/c182.0.716.716/13355672_1106457022756719_1922003005_n.jpg?ig_cache_key=MTI3NDg5NTA2NTI0OTk1MzI3NQ==.2.c
  • Joey_V
    Joey_V Posts: 8,603
    Those diffusers you have pictures are very expensive man... I wanted one but I'm not sure I'm willing to spend that much for diffusion... though it's artwork.
  • HzTweaker
    HzTweaker Posts: 1,077
    Joey_V wrote: »
    I have that very same Radio Shack issued decibel meter! I feel I must add its the only thing in that room that I have identical..(clears throat) B);):D:)
    This is a great thread Joey! Keep 'em coming.
  • WLDock
    WLDock Posts: 3,073
    Joey_V wrote: »
    Yeah, anything I end up doing will be DIY for that very reason.
  • Jaybeez
    Jaybeez Posts: 748
    Great set up and I'll bet your research and time have paid off big time. My listening space doubles as a recording studio so I can't put any holes through the two layers of drywall. I used these with some "L" brackets and it also worked. Yours looks way better though!
    2 Channel "Polk" Room:
    Marantz PM8004 Integrated
    Marantz SA8004 SACD Player
    WiiM Mini
    Polk 7B with RDO198s
    ^^^ That thing on the left looks like a medieval torture device of some sort! :s
    Looks like it would dig in & grip for all its worth.
  • Jaybeez
    Jaybeez Posts: 748
    Not to scale! :#
    WiiM Mini
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    Nice work, Joey.
    In the future, instead of using regular toggle bolts consider using "Togglers".
    They're a LOT easier to install and actually stronger. They also make for a smaller ceiling hole.
    They're available at your big box hardware stores and Amazon.
    https://www.amazon.com/TOGGLER-SNAPTOGGLE-Zinc-Plated-Channel-Fastener/dp/B0051IARUE/ref=sr_1_3?s=hi&ie=UTF8&qid=1489208308&sr=1-3&keywords=togglers
  • gurot1
    gurot1 Posts: 519
    edited March 2017
    I haven't seen these toggles before...seems like they don't require as big a drill bit as the ones I have used in the past.
    Awesome job on the clouds!
    lsim705,lsim706c,lsif/x(4)+mc80(atmos)
    rti6,csi5,fxi5
