Soundproof a pocket door
I'm planning to install a pocket door on our "game room" which is where I mostly listen to tunes. I think I will build a hollow core door and fill it with sound deadening material. Considering that the door cavity will be 1.5" wide at most, what would be the best material to use? Roxul?
Yep, my name really is Bob.
    VR3 Posts: 29,427
    I have solid core doors through out my house, blocks sound real well
  • mrbiron
    mrbiron Posts: 5,721
    VR3 wrote: »
    ^^^This. By the time you buy all material associated, you could have bought a slab and been done in an hour+-.
    Pocket doors probably aren't the tightest meaning there is the untreated void in the wall cavity where sound can easily travel. Maybe you can gasket that as well???
  • muncybob
    muncybob Posts: 3,238
    Yeah, I should have sealed that cavity and installed the pocket door when the walls were open.
  • DaveHo
    DaveHo Posts: 3,583
    Mass & an air tight seal are what determines the STC of any particular surface. Is an air tight seal even possible on a pocket door?
  • mrbiron
    DaveHo wrote: »
    You'll never achieve the seal on a pocket door but you can at least slow it down...possibly.
    There aren't any systems, that i know of, but some mickey mouse rigging can be deployed.
  • Joey_V
    Joey_V Posts: 8,600
    Not sure you can really seal a pocket door
  • K_M
    K_M Posts: 1,632
    Star trek did it....right?
    I would use a solid core door. Big difference in sound not being able to penetrate, but it will still get around the edges or gap easily.
    Our media room in our one house has a pocket door, and it was not really able to be effectively quieted enough, even with the Solid core heavy door.
    We Eventually installed a 2nd solid core swinging door, about 6 foot down the small corridor that led to the media room, that could be closed when almost total quiet was needed. That made a huge impact in reducing most all of the sound.
    So like dual doors, spaced about 5-6 feet apart and we just leave both open usually unless we have some fairly loud movie going.
    At first it was cumbersome, but now we grew used to the look of that set up.
  • K_M
    K_M Posts: 1,632
    DSkip wrote: »
    Joey_V wrote: »
    I've seen enough Sci-Fi movies to know that you can. >:)
    Poisonous gas is one thing.....sound quite another.. :#
