polk audio speaker box internal crossover
brettos096
hello.
i have a crazy problem and im wonedering if you can hlp me. i have a polk audio speaker box 10'' woffer one mid one tweeter. the problem u may ask. i was not getting any base, when i took out the speaker it had no magnet on it lol. so i went and bought a speaker. but on the crossover there are no wires for the woffer. maybe i just dont know any thing about polk. im confused. can you help at all.
tnx brett
tnx brett
Best Answers
Hi Brett,
Welcome to Polk's forum. In all likelihood your speaker uses a passive radiator (no voice coil or magnet needed). The speaker probably has a 6.5" active driver and this is what needs to be replaced. Do you know the model number of your speaker?
Regards, Ken -
Polk sells them through their customer service department available either at: 1-800-377-7655 select option 2 or via email to: polkcs@soundunited.com I believe they will ship to other countries. Also, they might be found on eBay but use the usual seller ratings for making sure you get a good unit.
Answers
im lost how do i see my answers
Hi it says sw101 i dont know if that hlps
Now i understand what it is. The active driver is a MW6502. I will not be able to get a replacement for this where i am. Can you recommend something for me to replace it with? thank you so much for your hlp.
where are you? MW6502 is very common on the used market and I believe Polk still sells new drivers
