Monitor 7B crossover Up grade Pics
    F1nut Posts: 51,940
    Read the values on the components.
  • Nightfall
    Nightfall Posts: 10,083
    You have good soldering skills?
    afterburnt wrote: »
    Village Idiot of Club Polk
  • pkquat
    pkquat Posts: 748
    You can twist the black and yellow caps to see the values as needed. If the wires break, you were planning on replacing them anyway :p Or you could cut the wires from the caps now.
    I could be WRONG but I might guess they are 12uF and 27uF (maybe 24uF)
  • pkquat
    pkquat Posts: 748
    xschop wrote: »
    Has anyone actually measured the inductor values for the 7B?
    7A or 7B? I thought the 7A had the peerless and the 7B had the SL2000. The "schematic_m7_orig.pdf" and "schematic_m7_rev.pdf" are for the SL2000 / RD0194 tweeters. The "schematic_m7_rev2.pdf" are for the SL2500 / RD0198 tweeters.
    I don't have 7A spec's, but I thought there was one schematic pdf floating around here for it.
    Related/Unrelated, I should have inductor values for the 5A and 5 Series 2 sometime this spring.
    F1nut Posts: 51,940
    pkquat wrote: »
    Indeed, you are wrong.
    The info was posted on the first page.
    For hippo's 7B's....
    12uF
    34uF
    2.7 ohm
    4.5 ohm
  • pkquat
    pkquat Posts: 748
    12uF
    34uF
    2.7 ohm
    4.5 ohm
    TY, :D
    pkquat wrote: »
    xschop wrote: »
    I was WRONG on both counts :(. I now see the 7B in on the cup.
    I also found a (the) schematic, but the inductors were not listed. :(
    http://forum.polkaudio.com/discussion/59876/special-monitor-7-what-should-i-do
  • nikolas812
    nikolas812 Posts: 2,915
    Nice to see my contributions to the forum are still going. Been a long time.
    I miss my 7b's. One of the better sounding polk's i've ever owned.
    Nik
