Audio Desk Ultrasonic RCM on the way...
nooshinjohn
My first Father's Day gift comes early...
http://www.stereophile.com/content/audio-desk-systeme-vinyl-cleaner#LZsFaF5RsQD7hJDE.97
looking forward cleaning about two thousand records... If any of you guys have records to clean, I will be happy to help.
Very nice. Just send it around to all of us.
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
I might be open to that actually. Thought of making it a group purchase and passing it around the group.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
I have been considering upgrading to an ultrasonic cleaner so please keep us updated. A VPI 16.5 RCM has been in use here for years with great results using the three step Audio Inteligence solutions (enzyme, cleaner, pure water rinse) on my used acquisitions. I do just the cleaner and clear water rinse on all new pressings. It makes an exciting improvement on many, but sadly doesn't fix permanent grove damage on those others...integrated w/DAC module Gryphon Diablo 300
server Wolf Alpha 3SX
phono pre Dynamic Sounds Associates Phono II
turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
speakers Rockport Mira II
cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
rack Adona Eris 6dw
ultrasonic cleaner Degritter -
Congrats on your "Ultimate" RCM, I don't have the collection or the bank account to afford a cleaner of the caliber...but if I did, I would!
Mike Reeter wrote: »Congrats on your "Ultimate" RCM, I don't have the collection or the bank account to afford a cleaner of the caliber...but if I did, I would!
I don't either, but desperate sellers can sometimes come in handy.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Just a quick word on this RCM... so far I have cleaned a half dozen records with it, all of which were in the pile of records that I wanted to keep, but needed better copies because the SQ was so bad I could not listen to them. Each one after cleaning, has earned the coveted MFSL record sleeve. The Audio Desk does the job like no other. Everything that has been written about it is true, and then some. More later, but if local polkie would like to give it a spin, just shoot me a pm.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Where is local?nooshinjohn wrote: »if local polkie would like to give it a spin, just shoot me a pm.
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
Los Angeles... literally saved me 150.00 in record replacement costs in a matter of minutes.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Just cleaned a 52 year old copy of The Beatles VI... it plays better the it ever has! This was my first Beatles album and was worn out by my mom before my 8 year old paws found it. I am shocked this can even be played anymore, much less sound as if it was just opened for the very first time.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Have a copy of Star Wars- The Force Awakens on vinyl... what a crap pressing this on is. Beyond any help whatsoever. I will see if it can be exchanged for another, but I doubt it.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
What's it cost? I had a VPI one but that kaput...Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
A nice "all in one" system. I would love to compare this with my in progress diy ultrasonic set up. I don't understand why you are limited to their proprietary cleaning solution unless it's a warranty thing?Yep, my name really is Bob.
Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
Google and Audiogon work quite well from what I hear anyway...
Just an update... the Audio-desk has taken every LP that was in my pile of records needing replacement and made them not only playable again, but actually turned them into near mint or VG copies all over again. Only one out of some 75 recordings that have been cleaned though this cleaner have been rejected, and it is a new copy of Star Wars the Force Awakens.
This is a first rate RCM in all respects.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
As my time with the Audio Desk draws to a close, I thought I would share some final thoughts. I have been continuously shocked each time I play an LP that has been scrubbed by the ultrasonic bubble bath. Though I do have about 30 records that were damaged so badly they will need to be replaced, the vast majority play to a level that exceeds my wildest expectation. I can now pull any record from my collection and know that I will be able to thoroughly enjoy the experience.
I already have a buyer lined up for it and will recover 95 percent of my initial investment. To use a machine of this caliber for the cost of purchasing a SpinDoctor has made the cleaning process an enjoyable experience. Someday I will have one of these as a permanent piece of my collection, but for now, I can heartily recommend picking up one of these RCM's if you can swing it, especially on the used market.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
You got a great price on a nice unit and are selling? Not planning to buy any add'l vinyl in the future?
I'm still holding out for a ultrasonic unit at a good price. Seen some cheapies on ebay but a Sonix or similar is what I'm hoping for. For the price of a Spin Doctor I would have gladly taken that off your hands.Yep, my name really is Bob.
My comment on the Spin Doctor meany that my total out of pocket will. Be abour a hundred bucks, not that I paid a hundred for a 4K machine. I won't be adding anything to my home for a long time with a newborn in the house, so no Ned to keep this when I could pay off the credit card used to purchase it.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Yea, I figured that was too good to be true. I need to make a decision and buy a US unit soon. I keep buying more vinyl but won't play them until they are cleaned.Yep, my name really is Bob.
There is one for sale on another site for $2100 from a reliable seller - original owner. This owner has the AD, a VPI, a KLaudio, and a Clearaudio Sonic.[
