Please tell me if this is not normal!
  • motorhead43026
    I wonder when Polk developed and tested the RDO's did they use 30 year old crossovers parts.
  • codycatalist
    That's a good question and probably a resounding no. I doubt they would go through the trouble to look for out of date caps, I'm sure they just went off the original specs. Either way that would be a bummer but a good excuse to replace these old tired parts.
    treitz3 Posts: 20,227
    The unwanted artifact that was provided in the video does not indicate anything that would be associated with a bad crossover. Just a connection.
  • Gatecrasher
    Gatecrasher Posts: 1,538
    edited February 2017
    It's amazing what a bad connection will do (even if it visually looks OK).
    I have another hobby which is the restoration of early SS pinball machines from the 70s & 80s. One of the first things I always replace are ALL the Molex connector pins. Even though they may look OK and even test OK, after 45 years the connectors are always less than optimal. You can clean and re-seat them and get by for a while but eventually they always give you problems.
    When you think of all the money some people put into things like expensive speaker wires just to have the final wiring inside the speaker cabinets connected with cheap spade connectors that over time lose their continuity, it makes the expensive speaker wires seem like a waste.
    I would totally-eliminate the connections (which is easy and inexpensive to do) before assuming anything else.
  • Unknown
  • codycatalist
    Yep2 wrote: »
    Had a hiss in my Boston tweets recently that i've never heard before.
    I tried everything.
    It was 8-10 degrees outside at the time.
    After time it went away, nothing since.
    I believe it was so cold everyone on my AC line had their heaters on HIGH!
    Hash in my AC line.
    8 degrees outside?! Add a 0 to the end and that's my weather almost year round. Gotta love the valley under the sun.
  • Unknown
  • ptrooper
    ptrooper Posts: 501
    I had the same issue with a batch ,being 3 out of 6 194's that i installed into my 2.3's last year,I really noticed this same problem while playing a few tracks of Dire straights "brothers in arms" and funny enough they were all slightly different.ie...bad one to worse one....... They weren't resonating nicely at all ,Quite sad actually as living here down under is a major drama to exchange but i will be swapping them in this next year !
  • codycatalist
    ptrooper wrote: »
    At least someone has experienced it before, makes me feel less crazy. I will still double check connections but I feel I'm just having bad luck.
  • codycatalist
    Yep2 wrote: »
    Its just bad Karma...
    Vhattt?! I thought I had good karma coming my way, I gave away an amp for free on here a couple months back. Oh world you are a cruel mistress.
  • motorhead43026
    motorhead43026 Posts: 4,056
    I found a wallet full of money in the men's room @ the casino, of course I turned it over security. I thought man, I am due some good karma for my good deed. Lost close to a
    $1000.00 bucks before I left the joint, nothing but bad luck all night.
  • codycatalist
    I found a wallet full of money in the men's room @ the casino. Of course I turned it to security. I thougt man I am due some good karma for my good deed. Lost close to a
    $1000.00 bucks before i
    Ouch. Simply... ouch
    I started to doubt myself and my diagnosis, so I went back and listened to the video again. I didn't realize you had the SL2000 in the other speaker at the time of the video. There is definitely one of two things going on. Either you loosened one of the connections leading to the RDO tweeter(s), which at this point is highly unlikely, or you have received defective tweeters.
    The sound coming out of the SL2000 is completely normal. The sound coming out of the RDO's are FUBAR. Try placing the SL200's back in and see if the unwanted artifacts remain. If they disappear, then the RDO's are defective. End of story.
  • codycatalist
    treitz3 wrote: »
    That's what I'm thinking. I've put one rd0 in and had issues but the SL was fine. Put both rd0s in and same issue in both. Put both SLs back in and everything was fine. I just hate reaching out for a 3rd set of replacements without dotting my I's and crossing my T's. Thanks for all thebhelp though guys. I even tried cleaning the terminals on the tweets and the spades, switching polarity EVERYTHING. Same results with the RD0s sounding like poo poo.
  • motorhead43026
    What are the odds of receiving 4 defective RDO's? That is unless there was a run of defective product.
  • codycatalist
    That's what I've been fighting with internally.
    txcoastal1 Posts: 13,519
    Is there anyone close to you with a similar speaker and 194's
  • codycatalist
    txcoastal1 wrote: »
    Not sure. I personally don't know anyone else big into audio.
  • vmaxer
    vmaxer Posts: 5,121
    Where are you located?
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    Anyone else out there with recently purchased 194's? Having this issue, chime in???
  • codycatalist
    vmaxer wrote: »
    Phoenix Arizona
  • vmaxer
    vmaxer Posts: 5,121
    Well, not even close.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • codycatalist
    vmaxer wrote: »
    Well think of it as a great excuse for a vacation in the beautiful desert oasis.
    To my ears, that noise isn't from a crossover issue, may not even be a tweeter issue. As Tom pointed out, sounds more like a connection issue or a cable issue. The RDO's have more detail in them than the SL's and that may be enhancing the poor quality of a cable in the loop.
    Try some different speaker cables or IC's, maybe flip the cables on the source component your using to start. Have anything laying around you can use to make this determination ?
  • motorhead43026
    I have some RDO's 194's that I purchased in December 2016, no issues. May not be the same batch, hard to say.
  • codycatalist
    tonyb wrote: »
    I can put back my monster cable. I figured my blue jeans would be fine. Will put old speaker wire back in to test.
  • [Deleted User]
    I ran into an issue very similar to this years ago in some custom speakers I was building. The side notches in the main tweeter holes were deep enough so the wood was forcing the connectors inward towards the magnets causing the diaphragm plates to bend and distort. Made the notches larger and problem solved.
    In my Monitor 12.2's, I had to open the terminal notches a little with a rat tail file for RDO-198's to drop in smoothly.
    Also make sure all 4 corners of the tweeter plate are settling down inside the routing. One corner sticking up is going to tweak the top plate when the screws are snugged up. That would put a bend to the diaphragm too.
    Easy test. Simply slide the tweeter out of the cabinet while playing and see if the issue continues or goes away.
  • [Deleted User]
    Correction. Should say in 1st paragraph the terminal clearance notches weren't big enough.
  • codycatalist
    I switched out the speaker wire and think that may be the culprit. I am going to test further today and make sure.
