Please tell me if this is not normal!
Second pairing RD0 tweeters and same issue again. I'll include a link to a YouTube video, when you listen to the RD0 you can hear a faint buzzing at the end of the piano chords. It is hard to hear I'm the video but I can still point it out.
let me know if this is what you have experienced or not.
https://youtu.be/FBuOk2FkJOA
«13
  • codycatalist
    You'll notice there is a spike in white noise at the end of the chords. This is the buzzing I'm talking aboit
    treitz3 Posts: 20,208
    Check connections within the speaker and leading to the speaker.
  • codycatalist
    treitz3 wrote: »
    Issue doesn't occur with my SL2000s so I know it's not an internal speaker connection. Beyond that the only connection I can make with their tweeter are the terminals which I popped right on without issue. Popped them on all the way and made sure there wasn't a connection issue there...
  • codycatalist
    Unless the red dye on the positive terminal needs to be removed. I wouldn't figure that to be the case since there are no other indications of terminal type.
    I will admit, I may be wrong but experience tells me from that issue that there is a connection issue. It's not from the source and it's not from the amplifier.
  • codycatalist
    treitz3 wrote: »
    I can understand that. What I can't is how my older tweeter works fine and still thinking it to be a connection issue. I mean plug black wire to positive, white to negative. I don't have any play in the female when I have them connected. On top of that I already reversed polarity just to make sure but same issue.
    It could be an internal issue with the tweeter itself. Try swapping a known RDO that does not have this issue within the same speaker and listen for the same issue.
  • codycatalist
    treitz3 wrote: »
    I wish I could. Ordered my first pair last week, had this issue. Got a replacement pair sent out, same issue. Now I'm here o:)
    Hmmm, okay. So you say that the connection from the terminal of the wire to the tweeter is okay.....what about any loose connection between the terminal of the wire and the connection itself?
    I am betting it's between the speaker terminal and the tweeter. Somewhere in that mix, there is an issue.
    F1nut Posts: 52,162
    Are those 194 or 198?
  • codycatalist
    F1nut Posts: 52,162
    I can hear a lot of hiss with the SL2000, which sounds more like crackle with the 194.
  • codycatalist
    One RD0 in the new shipment seems like it doesn't have this problem. First one I tried was horrible, lownor high volumes I would get slight breaking up and buzzing.
  • codycatalist
    I get the crackle but I get more of a hiss than a crackle on the RD0.
  • codycatalist
    It's a weird sound to describe. Like static breaking up the sound on certain parts. It's not on all frequencies, I notice it more with piano, harmonica etc.
  • Gatecrasher
    Gatecrasher Posts: 1,538
    edited February 2017
    It's probably the connector. After they are removed a couple times and exposed to the elements they get loose and the plating wears off. Try new connectors and make sure the surfaces are good. When I had my SRT subwoofer drivers repaired I replaced all the connectors for good measure.
  • codycatalist
    codycatalist Posts: 2,661
    Think I could have had a crossover issue I couldn't hear in the SLs that is revealed on the RD0?
  • motorhead43026
    Are the crossovers stock?
  • codycatalist
    Indeed. I know they have a shelf life but I wouldn't figure there was a major issue since it was not audible on my old tweeters that I've swapped back and forth with the RD0. Same noise with the RD0, none with the 2000.
  • codycatalist
    Scratch that, started out nice but eventually started making the same noise.
  • motorhead43026
    Time to rebuild those crossovers.
  • codycatalist
    Yeah it's overdue but think that could be the issue here?
  • gmcman
    gmcman Posts: 1,864
    Could it be the SL2000 just doesn't resolve the upper end like the 194 does? Have you tried a different amp/receiver?
    I would check all the connections, but... you could have been that unlucky with the 194's.
  • codycatalist
    gmcman wrote: »
    I'll have to break out my marantz and see what happens. Haven't had an issue before with the amp but doesn't mean it isn't the culprit here.
    I highly doubt it's the crossovers, unless there is an issue in that network and on that speaker.
  • codycatalist
    treitz3 wrote: »
    I highly doubt it's the crossovers, unless there is an issue in that network.
    I didn't believe them to be the issue but how would I really know without hearing another pair of 2bs which I haven't.
    Ya' lost me bud. What is a 2B and what does this have to do with your issue?
    Basically, what I am saying is swap the tweeter with the other speaker. Does the issue follow or is it corrected? This will help to isolate the issue and if the issue persists, to diagnose what is wrong from there.
  • codycatalist
    treitz3 wrote: »
    SDA 2b. What I was saying is I wouldn't really know if I had a cross over issue unless I heard another pair of the same speaker confirmed to not have issues.
    I've swapped tweeters between the speakers and issue is in both but only RD0s.
    PM sent
