Bi Amping LSiM 703s?
Recently bought Polk's LSiM 703 bookshelves. Happy with them but not sure I am fully utilizing their ability.
Does Bi Amping really help?
Does 12 gague wire help?
Thoughts before I proceed are appreciated.
AVR: Marantz SR 5011
L/ R: Polk Audio 703 LSiM (Bi Amp'd)
C: Polk Audio 255c - LS
R: Def Tech
Sub: PSW 505 (12 inch)
DVD: Oppo UDP 203
TV: 2016 Sony XBR 75X850D
    txcoastal1 Posts: 13,134
    What is your associated gear?
    And welcome
  • Kingkwas
    Being powered by Marantz SR 5011. Polk PSW 505 sub
    R: Def Tech
    DVD: Oppo UDP 203
  • PSOVLSK
    PSOVLSK Posts: 5,086
    I would amp before I tried to bi-amp. Nice AVR, but very few (if any) AVR's are going to make them sound their best. I owned a pair and loved them...great speakers.
  • rooftop59
    rooftop59 Posts: 7,987
    Read up on bi-amping here in e forum. With an AVR, the power significantly decreases with each channel you add. So most AVRs that are rated at 100 wpc might do that for two channels driven (maybe), but at 5-7 channels driven that number tanks to as low as 35-40 wpc. So what good would bi-amping do? Get a used external amp from parasound, b&k, rotel, etc. that puts out at least 100 wpc (more is better) and I think you will hear the difference.
    Welcome and good luck.
    Game Room 5.1.4:
    Bedroom 2.1
  • sgtmick63
    I have a pair of 703's. First used a Yamaha rx-a2010. They sounded pretty good with a Yamaha. Then I went to a Parasound 2250 what an improvement in the sound. Them I went to a Parasound A31. The A31 brought the sound quality to a new level. Try to find a used 2250. You will not be disappointed.
  • Kingkwas
    Whoa. The Parasound is expensive. More than my AVR. Do you still Bi Amp the speakers with a external amp?
    R: Def Tech
    DVD: Oppo UDP 203
  • Kingkwas
    Does running the L/R thru an external amp cause any problems in a HT setup with other speakers? Like timing being off?
    R: Def Tech
    DVD: Oppo UDP 203
    tonyb Posts: 32,908
    Kingkwas wrote: »
    No....plus you really don't need to bi-amp the 703's, they are an easy speaker to drive with most any receiver/amp.
    Good sound is not just the job of the speakers. Your electronics, cables, source material/room also play a part in what your going to hear.
  • gp4jesus
    gp4jesus Posts: 1,969
    edited February 2017
    Kingkwas wrote: »
    Can't hurt to try it if youre only doing 2 channel. You decide. Either way a separate amp will likely make a greater dif in your listening pleasure.
    Kingkwas wrote: »
    Does 12 gauge wire help?
    IME* mo' bigga' mo' betta'.
    * 37 years
    Tony
    Samsung 60" UN60ES6100 LED Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga - LCR mids, inside* & out 8 ga Powerline: LR woofers, inside* & out *soldered LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & “Plugged*” Mids - 981, connected w/MP Premiere ICs Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s *Xschop's handy work
  • K_M
    K_M Posts: 1,627
    rooftop59 wrote: »
    We have several AVR's of different brands, prices and Vintages.
    Found when running in straight 2 channel mode, any of them are able to sound good and go fairly loud. Only the cheaper ones, when in 5 channel mode, and at high levels run out of steam easier.
    on our separate amps, yes there "Is" a difference, but not nearly as pronouned as I have seen many say. It matters mostly if running without a sub and at high levels for sure, but at moderate levels or even somewhat loud, mostly a non issue, even with the cheapo yamaha to our surprise.
    It depends on a lot of factors.
    F1nut Posts: 49,848
    A dedicated amp will provide noticeable improvements at low listening levels verses an AVR if one knows how to listen.
  • K_M
    K_M Posts: 1,627
    A generalization followed by a flawed conclusion. Logical Fallacies.
    Unless one has heard every Amp and every AVR.......One is making a generalization based on one's own very limited personal experience or simply their opinion or likes.
    "If one knows HOW to listen" falsely implying that anyone that disagrees or does not share the same opinion, does not know how "to listen".
    One can not "Trust their ears" and at the same time put out absolute statements.
    Absolute statements have no place in a subjective endeavor.
    You can not have it both ways.
    F1nut Posts: 49,848
    Followed with....
    You have a bad habit of sticking your foot in your mouth.
  • K_M
    K_M Posts: 1,627
    Followed with....
    What we hear is what we hear..........
    And at the same time, you seem to have make many statements that you believe must apply to all and be absolutely true, in an objective sense.
    A subjective hobby can not have objectively true answers.
    You are merely making subjective comments and hoping they pass as facts to the uninitiated.
    If you have heard literally every amp and ARV, pardon me for being wrong.
    F1nut Posts: 49,848
    You are the one taking everything I say as fact, so that's your problem. Just because I offered an opposing view based on my near 50 years of experience in this hobby is no reason to get your panties in a bunch.
  • lightman1
    lightman1 Posts: 10,776
    You both suck. Deal with it.
    LOL
  • Msabot1
    Msabot1 Posts: 2,098
    Regardless of who's make of speaker system that you use..you will never get the desired effect bi amping using a AVR...period.
    tonyb Posts: 32,908
    Msabot1 wrote: »
    This ^^^^^
  • K_M
    K_M Posts: 1,627
    "If someone knows how to listen"???
    Implying someone that disagrees, does not know how to listen.????
    Your personal "opinions" are just that. Something that applies to only yourself and your beliefs, in "What you hear".
    Telling people they are wrong constantly has no place in a subjective hobby.
    Me being Female, has nothing to do with my comments.
  • gp4jesus
    No more mud slinging please
    F1nut Posts: 49,848
    K_M wrote: »
    A majority of folks here know what my comment, "If someone knows how to listen" means. Same with the panties comment. You are the one implying things.
    Frankly, it saddens me to see you embarrass yourself attacking me.
  • Nightfall
    Nightfall Posts: 10,073
    afterburnt wrote: »
    Village Idiot of Club Polk
    tonyb Posts: 32,908
    K_M wrote: »
    I think your missing his point KM. In respect to "how to listen", many don't, just a simple fact. To be fair though, many don't care either. That's where many in this audio hobby of ours part company and opinions usually follow along those lines.....preferences aside.
    In regards to amps not making a difference at lower volumes.....all depends, most times it's not the amps fault but a failure to address other shortcomings within one's system. Could be cabling, impedance issues, synergy, material you listen to, etc. Most times than not too, using an amp that requires 2 volts on the input to drive to full power from a receiver that only puts out 1 volt on the outputs may also be a reason your lower level details are not as pronounced as they are once the volume gets turned up.
    Sometimes in this hobby, we like to place blame on a piece of gear when in reality we should be looking at the sum total of all parts included. For instance, XYZ speakers sound horrible, but then no steps are taken to address why and some are more content just flipping speakers. Being able to discern signature sounds of brands or individual pieces helps to find what might synergize in your system to play to your preferences. That takes some critical listening abilities, not your passive casual ones. That's more to F1NUTS point, I think anyway, he may have other observations. Just sayin' is all, chill out and have some ice cream. lol Nobody frowns eating ice cream. :)
  • K_M
    K_M Posts: 1,627
    tonyb wrote: »
    K_M wrote: »
    That takes some critical listening abilities, ***not your passive casual ones***. :)
    I get it, to some degree, the realm of good listening skills is somehow only in older, mostly white males. But I suppose the skill of talking down, being right all the time, and a patronizing tone, is part of that listening skill set.
    heiney9 Posts: 25,092
    Every amp I have used in my system sounds markedly different. K_M, I can tell you've never critically listened to a higher end amp. If you did, your opinions would be different.
    To the op, biamping with an avr is a waste of time and biamping those speakers isn't necessary.
    You don't really state what your goal is, so I can't really make a recommendation.
    tonyb Posts: 32,908
    K_M wrote: »
    tonyb wrote: »
    K_M wrote: »
    Dear Lord, is everything about male/female to you ? That is and was not my intended meaning and I think you know that. I did not apply gender to anything in my post.
    I know this is the internet and all, but once your in tune to the multiple personalities around the forum you can better decipher what is condescending and what is sarcasm. It's fairly easy to misconstrue statements on the internet. Go eat some ice cream. Sheesh....
  • K_M
    K_M Posts: 1,627
    heiney9 wrote: »
    That is a logical fallacy.
    Circular reasoning.
    Anyone that disagrees obviously does not have a legitimate understanding, if they did, they would agree with me.
    Never said anything about amps sounding the same, wrong person.
    I get what you are trying to say, but it is simply not correct in my case.
    I think we are back to the same logic I see several use in this forum:
    Anyone is free to disagree, but they are always wrong......lol
  • ZLTFUL
    ZLTFUL Posts: 5,640
    For anyone who needs a TLDR for *ANY* one of @K_M posts, I offer:
    20080202231407
  • K_M
    K_M Posts: 1,627
    tonyb wrote: »
    K_M wrote: »
    tonyb wrote: »
    K_M wrote: »
    No everything is not Male/Female, sorry to mention that.
    I think I see a case of "5 guys say capacitor X is horrible"
    someone else comes in and says " I think capacitor X is great"
    And 5 guys reply back with "Well obviously you like it, you lack the experience to realize how bad capacitor X truly is", meanwhile they have no idea what the dissenting persons actual experience is, nor why they like something they do not.
