Polk db6501 air core inductor replacement?
btijet
Very disappointed in these Polks as they have lasted a month till the woofer stopped working.
The air core inductor on the board has broken on one side. Where can I get a replacement air core inductor?
Prefer to buy replacement part rather than rolling one as I have very little electronic knowledge.
Best Answer
Hello,
This is a link to the company that handles Polk's car audio products in Australia:
http://www.directed.com.au/
Hopefully they can help you.
Regards, Ken
Answers
Hello,
The best source for replacements would be via Polk's CS department at: 1-800-377-7655 select option 2.
Ken -
I suspect the Canadians are up to no good again. Check for maple syrup residue.
I'm not Canadian, Australian in fact
Your air cores spin backwards, then.
Welcome to the nuthouse. Hang around. We got some cool Aussies in the midst here.
Rock on! -
KennethSwauger wrote: »Hello,
Regards, Ken
Thanks mate, sorted it out after a month of this post. Ended up buying another Cross over from these guys $70. That blow as well after another 2 months took it back. Guy had to speak to manager or something came back with the newer model or mm model. Wasn't happy as it's different. But it's been about 5 months+ no headaches so I'm wrapped
