ok, youse guyses are gonna roll your eyes...
mhardy6647
A while back, I bought a pair of Canare speaker cables
http://forum.polkaudio.com/discussion/174458/canare-wire-it-just-keeps-showing-up
I've been using them here of late with the Nelson Pass/First Watt/DIY "Amp Camp Amp" variant that nearly magically showed up recently on my doorstep.
OK, today I did - finally - A/B the amp with my normal amp (a slight variant of the JE Labs "Simple 2A3" design) with the "Amp Camp" amplifier.
Being one lazy m - of - o, I just switched the cables
I hadn't tried the Canare cabling on the 2A3 amp before.
holy moly.
I was using "interesting" cabling on the SE 2A3 amp before (some cryo-treated 18 AWG magnet wire stuff from an actual brand of some sort) - that I thought sounded pretty good (i.e., better than zip cord).
I am in a very different place now.
OK?
holy moly.
OK?
Rolling my eyes alright...how did you get dkfreebird's cables?
Congrats on your new find! Now, you need to start at one end of that warehouse of yours and see what a difference the cables make on all things functional.
That should keep you busy for a while. -
I'm not actually cabling naive; just loath to spend big bucks on small pieces of wire.
If I started now, I'd die of old age before I got all of the LPs here cleaned and listened to. I don't need another set of tasks to do
"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Who made that stuff? Obviously anything sold by the OP on that cable must have been underpriced!Aaron
Enabler Extraordinaire -
Instead of rolling eyes, can I just laugh
Great! Their stuff is not so bad and of course cheap!
On the other serious side - what are your takes on those amps?Aaron
So if I'm reading this correctly the canare is the better sounding cable?
The "amp camp" amplifier is a very good sounding piece of hardware, top to bottom. It has the finesse and immediacy of "any" good single-ended* amplifier.
To my ears, on the current, slightly bizarre configuration of my Franken-Duplexes, and using the same preamplifer, the single ended 2A3 amp outdoes the ACA. However, the 2A3 amp (also DIY) was about 5x the cost of the ACA (both DIYs, so that's a rough estimate of the delta). The output impedance of the preamp I am using may not be optimal for the ACA (or maybe for the 2A3 amp, either, truth be told).
Oh, and the ACA certainly has better HF extension/output than the 2A3 amp (which has good, but not great OPTs on it).
The Canare wire has improved the depth, spaciousness ('separation'), and clarity compared to the cabling I've been using on the 2A3 amp.
The ACA had sounded so good with the Canare cables that I decided that, when I went back to try the 2A3 amp (an "A/B" test, which I've been meaning to do) I knew I wanted to try them on the tube amp. Glad I did.
You guys can laugh, poke fun, whatever --- just please, please please don't goad me into putting $2k cabling on a $1.5-ish k amplifier
Please?
* Remember, all single-ended amps are Class A, but not all Class A amps are single-ended. -
OK.....I just fell off my chair. Lol I'm laughing so hard I have To go pee. LMAO.HT SYSTEM-
lsi 9's -
motorstereo wrote: »So if I'm reading this correctly the canare is the better sounding cable?
Yes.
Better than what, you may ask?
I am glad you asked.
http://www.jwaudio.net/Cryo-Nova-Speaker-Cables.html
(from their website -- which still exists, it appears) -
Get the net, Tony.....this one might fight a little before landing in the boat. -
Too funny.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
The CryoNovas must have just thawed out, Mark! You should have put them outside in the NE winter weather for a little while to get them prepped for action again. No wonder they lost it.
I haven't laughed this hard in days, great thread guys!! What were we talkin' about? O, cables...or was it amps? Anyhoo, great fun!!Thorens TD125MKII, SME3009,Shure V15/ Teac V-8000S, Denon DN-790R cass, Teac 3340 RtR decks, Onix CD2...Sumo Electra Plus pre>SAE A1001 amp>Martin Logan Summit's
This one is mantel material Russ. lol
Oh crap Mark, if you ever wanted to explore cables you don't have to sell 20 acres to get there. So much on the used markets for a couple hundies it's ridiculous.
You know my theory to keep the other half from snuffing you out in your sleep, if you want something, sell something. Judging by the looks of that audio room of yours, your not shy of things to sell either.HT SYSTEM-
lsi 9's -
Yeah, Mrs. H subscribes to that theory, too. I haven't bought into it yet, unfortunately
You want me to send you some IC's to go with the Canares? You can use them to hookup that "common law" phono amp you got.
What i am doing here is just prepping you for when you send me the ACA and you never see it again. That's a fair trade in my book....
Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
At the moment, as best I can figure it, the ACA sort of belongs to the Forum -- although, as of now, one kind benefactor is "all in" for its purchase price (and it ain't me)!
I am going to post a separate thread -- probably two, actually -- on that subject anon. Still fomenting.
I look at that little Reduction, sittin' there like an eager puppy, very often and get a good ol' tinge of guilt goin' about that, too.
Again, there's a thread to be born around that topic, too.
Since I know our buddy Halo's entered the phono preamp fray, now (or soon) is probably a good time.
Does any of the above make any sense at all?
BlueMDPicker wrote: »
Lmao.....and coming from a professor one has to ask how many former students left his class scratching their heads.
Just bustin' balls Mark, but ya have to admit....it is pretty darn funny.HT SYSTEM-
lsi 9's -
Even as a teacher/lecturer, I always figure that if I cannot inform, I can at least entertain.
Actually, my previous, ill-focused post (actually this whole thread) is my tongue-tied way to express my deep & sincere appreciation for the incredible generosity that is shown by so many people on this forum.
... and words really do fail me when I try to do so.
oh -- and -- both of the amplifiers mentioned in the original post really do sound mighty fine with them Canare cables.
but now I'm repeating myself
I'm slightly confused. lol. What is the Reduction? This? http://bottlehead.com/product/reduction-phono-preamplifier-kit/mhardy6647 wrote: »At the moment, as best I can figure it, the ACA sort of belongs to the Forum -- although, as of now, one kind benefactor is "all in" for its purchase price (and it ain't me)!
I remember hearing @SCompRacer posting something about the bottlehead gear, I think with a custom made wood base that looked really nice. I found the photo:
HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 10E
HT: Samsung 75QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
Yes, the Reduction is the second generation of Bottlehead's Seduction two-stage 6DJ8 passive RIAA (MM) phono preamp. I built a very early Seduction kit long ago; mrbiron built a Reduction some while back, then entered what biologists refer to as "log phase" with his family
This is a Seduction:
DSCN5316 by Mark Hardy, on Flickr
P1020763 by Mark Hardy, on Flickr
This is mrbiron's Reduction (still being held hostage at an undisclosed location as of this writing):
DSC_2913 by Mark Hardy, on Flickr
mrbiron lent his Reduction to me to compare to some of the other "phonostages" here in the frozen white North -- having no idea that it would disappear for year upon year as he waited, patiently, for a formal report on how it compares to other stuff.
I am actually planning to fire it up again today & spend some quality vinyl time (Mrs. H has a birding thing today on the North Shore down in MA). Further details as events warrant.
Back on-topic (is there a topic?):
That Eros is freaking beautiful -- that's Doc Bottlehead's higher-end phono preamp, if memory serves.
yeppers. http://bottlehead.com/?product=eros-phono-preamplifier-kit
