entry tube preamp
marvda1
here's a great price on an entry level tube preamp. don't know the seller.
http://www.audiocircle.com/index.php?topic=147872.msg1581917;topicseen#new
Puritan PSM156
Puritan PSM156
What would you recommend for a new entry level tub pre?2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
^^ That will be a tall order to find these days! ^^ Totally agree though!VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
Puritan PSM156 -
About $800.2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
I've just been looking on the 'Gon and I realize I'm gonna have to up my budget.2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
Toledo Oh.2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
knowing how good this musical paradise dac is you might want to check their preamp out.
http://www.musicalparadise.ca/store/index.php?route=product/product&product_id=81Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Thank you. I'll check that one out.2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
How bout a Rogue Audio Metis Magnum....
Kev although that looks like a wonderful piece, it's a little more than I can spend. Maybe something that I could find on the used market2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
Check out the one on EBay for 875 obo....I almost bought it but need a tubed pre with more outputs....you probably could get it for less.Kev although that looks like a wonderful piece, it's a little more than I can spend. Maybe something that I could find on the used market
Instead of starting another thread, I have a SS amp on the way pending funds and have been looking hard at other Rogue or Cary tubed pre amps. Budget is around 1600ish and used is fine....I could have my arm twisted to spend more if it was one of those pieces I would end up keeping for 5 years or more...any other ideas out there folks?
