entry tube preamp
here's a great price on an entry level tube preamp. don't know the seller.
http://www.audiocircle.com/index.php?topic=147872.msg1581917;topicseen#new
Puritan PSM156
  • xsmi
    xsmi Posts: 1,804
    What would you recommend for a new entry level tub pre?
    2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • george daniel
    george daniel Posts: 12,096
    Dodd ELP
  • MrBuhl
    MrBuhl Posts: 2,419
    ^^ That will be a tall order to find these days! ^^ Totally agree though!
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • marvda1
    marvda1 Posts: 4,964
    xsmi wrote: »
    what's your budget?
    Puritan PSM156
  • xsmi
    xsmi Posts: 1,804
    About $800.
  • xsmi
    xsmi Posts: 1,804
    I've just been looking on the 'Gon and I realize I'm gonna have to up my budget.
  • xsmi
    xsmi Posts: 1,804
    Toledo Oh.
  • marvda1
    knowing how good this musical paradise dac is you might want to check their preamp out.
    http://www.musicalparadise.ca/store/index.php?route=product/product&product_id=81
    Puritan PSM156
  • xsmi
    xsmi Posts: 1,804
    Thank you. I'll check that one out.
  • kevhed72
    kevhed72 Posts: 5,187
    How bout a Rogue Audio Metis Magnum....
  • xsmi
    xsmi Posts: 1,804
    Kev although that looks like a wonderful piece, it's a little more than I can spend. Maybe something that I could find on the used market
  • kevhed72
    xsmi wrote: »
    Check out the one on EBay for 875 obo....I almost bought it but need a tubed pre with more outputs....you probably could get it for less.
    Instead of starting another thread, I have a SS amp on the way pending funds and have been looking hard at other Rogue or Cary tubed pre amps. Budget is around 1600ish and used is fine....I could have my arm twisted to spend more if it was one of those pieces I would end up keeping for 5 years or more...any other ideas out there folks?
