Polk SDA 2 speakers receiver and amp advice
rkempf
I have a set of Polk SDA 2 speakers from a friend of mine. I really new to audio devices can anyone recommend an entry level receiver and amp to hookup? I have no idea what is required. I mostly would use they setup for movies on my tv and a turntable
Answers
How big is your room and how loud do you play?
If the answer is not that big and not that loud, then I've had great success with a Harman Kardon 3490 receiver. Pretty cheap on the used market.
If the answer is kind of big and kind of loud, then I would suggest a preamp and power amp combination.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
I used a Pioneer A-656 2x70 rms into 8ohm (probably about 90wpc into 6ohm) for my SDA 2B for many years. Sounded good even when played loud but I always felt the deserve more power. I recently got an old Nad 270 (2x120w rms into 8ohm) power amp and it sounds great. I think powerhouses like the Adcom gfa 555 (200wpc) are popular for driving SDA speakers. More power and high damping factor are your friend.SRS 1.2 TL | SDA 2B Studio TL | NAD M51 preamp/dac | DIY SET 300B tube amplifier | Cambridge Audio Azur 851W | Chromecast Audio | RoPieee Roon Raspberry Pi endpoint
hochpt21 Not that big and not that loud, just quality. Do I even need an amp? or just a good quality receiver will work fine?
Good quality are the key words, but yes a receiver would work.
You'll want to make sure the receiver is rated to 4 ohm. The one I mentioned above is high-current, 4 ohm stable, has a decent phono stage and an even better DAC.
If you're looking for entry level...its hard to beat.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
Thank you , What do you think about Onkyo TX-8410? I know someone that is selling, I belive the impedance can be changed to 4 ohms
yea don't do that switch thing it'll just handcuff you more usually by limiting current. -
Correction: Above I said I have a NAD C270 (2x120W) but mine is C272 (2x150W). The C272 works very well with my SDA 2B, plenty of power ...and probably the C270.
SRS 1.2 TL | SDA 2B Studio TL | NAD M51 preamp/dac | DIY SET 300B tube amplifier | Cambridge Audio Azur 851W | Chromecast Audio | RoPieee Roon Raspberry Pi endpoint -
Ok so my sister gave me a pioneer sx-251r to borrow will this work until I can afford something that matches up better
Just a step above a transistor radio.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
– Kevin Alfred Strom
Idolizing a politician is like believing the stripper REALLY likes you. -
Thank you all for your input. Got the pioneer connected and works well for my needs now. I will take all your advice when I ready to upgrade.
Ps these speakers sound awesome! -
The SDA-2s, will bring just about any receiver to its knees in seconds, especially with movie sources. They're 4 ohm nominal, and will drop well below that at certain frequencies. If you must use a receiver, try to find one with pre-amp outputs for the front left and right channels. You can add a common ground power amp later.Home Theater/2 Channel:
dhsspeakerservice.com/ -
The opportunity came for me to purchase a Pioneer sx 750 tomorrow locally. What do you have to offer about this receiver?
At 50w per channel whats to like. It sure won't drive any SDA's.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
I have a Pioneer SA 8500 and it drives my SDA 2's just fine. Very efficient speakers.
90DB is not exactly what I would call 'very efficient' speakers. I'd say they are intermediate on efficiency. I'm driving my 1C's with a nice restored Technics SU-V909 with 120watts. They do fine.
I have a Technics SU-V909 mines Silver it has also been restored, have had a pair of AR 58s hooked up to it for years I've had a pair of 2Bs and a pair of CRS+'s hooked up to it without breaking a sweat. I believe that integrated is the best one Technics ever made.Home Theater
