Polk SDA 2 speakers receiver and amp advice
rkempf
rkempf Posts: 6
edited January 2017 in Vintage Speakers
I have a set of Polk SDA 2 speakers from a friend of mine. I really new to audio devices can anyone recommend an entry level receiver and amp to hookup? I have no idea what is required. I mostly would use they setup for movies on my tv and a turntable
Answers
  • hochpt21
    hochpt21 Posts: 5,423
    How big is your room and how loud do you play?
    If the answer is not that big and not that loud, then I've had great success with a Harman Kardon 3490 receiver. Pretty cheap on the used market.
    If the answer is kind of big and kind of loud, then I would suggest a preamp and power amp combination.
  • hauxon
    hauxon Posts: 161
    I used a Pioneer A-656 2x70 rms into 8ohm (probably about 90wpc into 6ohm) for my SDA 2B for many years. Sounded good even when played loud but I always felt the deserve more power. I recently got an old Nad 270 (2x120w rms into 8ohm) power amp and it sounds great. I think powerhouses like the Adcom gfa 555 (200wpc) are popular for driving SDA speakers. More power and high damping factor are your friend.
    SRS 1.2 TL | SDA 2B Studio TL | NAD M51 preamp/dac | DIY SET 300B tube amplifier | Cambridge Audio Azur 851W | Chromecast Audio | RoPieee Roon Raspberry Pi endpoint
  • rkempf
    rkempf Posts: 6
    hochpt21 Not that big and not that loud, just quality. Do I even need an amp? or just a good quality receiver will work fine?
  • hochpt21
    Good quality are the key words, but yes a receiver would work.
    You'll want to make sure the receiver is rated to 4 ohm. The one I mentioned above is high-current, 4 ohm stable, has a decent phono stage and an even better DAC.
    If you're looking for entry level...its hard to beat.
  • rkempf
    rkempf Posts: 6
    Thank you , What do you think about Onkyo TX-8410? I know someone that is selling, I belive the impedance can be changed to 4 ohms
    pitdogg2 Posts: 27,340
    rkempf wrote: »
    yea don't do that switch thing it'll just handcuff you more usually by limiting current.
  • hauxon
    hauxon Posts: 161
    Correction: Above I said I have a NAD C270 (2x120W) but mine is C272 (2x150W). The C272 works very well with my SDA 2B, plenty of power ...and probably the C270. :)
  • rkempf
    rkempf Posts: 6
    Ok so my sister gave me a pioneer sx-251r to borrow will this work until I can afford something that matches up better
  • Just a step above a transistor radio.
  • rkempf
    rkempf Posts: 6
    edited January 2017
    Thank you all for your input. Got the pioneer connected and works well for my needs now. I will take all your advice when I ready to upgrade.
    Ps these speakers sound awesome!
  • westmassguy
    westmassguy Posts: 6,850
    The SDA-2s, will bring just about any receiver to its knees in seconds, especially with movie sources. They're 4 ohm nominal, and will drop well below that at certain frequencies. If you must use a receiver, try to find one with pre-amp outputs for the front left and right channels. You can add a common ground power amp later.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • rkempf
    rkempf Posts: 6
    The opportunity came for me to purchase a Pioneer sx 750 tomorrow locally. What do you have to offer about this receiver?
  • motorhead43026
    motorhead43026 Posts: 4,031
    edited January 2017
    At 50w per channel whats to like. It sure won't drive any SDA's.
    txcoastal1 Posts: 13,519
  • I have a Pioneer SA 8500 and it drives my SDA 2's just fine. Very efficient speakers.
  • 90DB is not exactly what I would call 'very efficient' speakers. I'd say they are intermediate on efficiency. I'm driving my 1C's with a nice restored Technics SU-V909 with 120watts. They do fine.
    gudnoyez Posts: 8,174
    pavlograd wrote: »
    I have a Technics SU-V909 mines Silver it has also been restored, have had a pair of AR 58s hooked up to it for years I've had a pair of 2Bs and a pair of CRS+'s hooked up to it without breaking a sweat. I believe that integrated is the best one Technics ever made.
