Any help for my Sony C222ES SACD player
Always worked great. Now drawer will not open or play anything? Any thought before permenant retirement? Thanks. Dul7nseh1ne3q.jpeg
    F1nut Posts: 51,891
    The belt could stretched out, even broken or it's possible a CD is jammed inside. Take the cover off to inspect.
  • mrloren
    mrloren Posts: 2,473
    yup what F1Nut said. These have belts or plastic gears that wear out. Could be an easy fix.
  • Dabutcher
    Dabutcher Posts: 2,606
    Thank you. Peace. D
  • Dabutcher
    Opened it up and removed the four discs. The fifth one was locked into cd transport spot. Figured how to release it . Player opened and closed ,then locked up again. Loved this player. Oh well,time to retire. Thanks for the help. D
    F1nut Posts: 51,891
    Could be a bad belt, could be a bad optical pickup......
    Does the tray spin around to each disc location looking for a CD to read after it closes?
    mhardy6647 Posts: 35,157
    This would be my guess as well (the belt, that is) -- cover's easy to remove & the little drive belt is easy to see/get to (at least on the "normal" Sony CD changers).
    The Yamaha changers have this problem, too. I have been known to fix those, temporarily, with small rubber bands -- and, no, I am not proud of that.
