SDA 3.1TL pin-blade connector
Hello -wondering if anyone knows a part # and description for the interconnect connector for the 3.1TL's -as the 2 pin din speaker connectors i ordered are not the correct ones.-the connector i have has the blade off center vs. in the middle of the connector.
-ive attached a pic of the connector for reference etc...
  • I don't know the part number..maybe polk CS will however if you use pin/blade and have a common ground amp you can just use an rca connection as the pin is what sends the signal between the speakers. You can also go with SpeakOn connections too.
    F1nut Posts: 51,858
    Neither the male or female parts are available from anyone.
    Your best option is to use Neutrik SpeakOn connectors. A search here will show many examples.
  • pxm
    pxm Posts: 4
    thank you for your response(s) -was trying to keep it as simple as possible by searchig out the original part but you've confirmed my suspicions etc..
    -my mono blocks are grounded bridge ( negative output is common to chasis ground) so i should be good to go with the RCA solution if i go that route.
    thank you again for your feedback
    -pxm
  • lawdogg
    lawdogg Posts: 469
    edited December 2016
    It's been proposed that since the blade is grounded, only the pin need be connected. An RCA cable will work to connect pin to pin. (E.g.: http://forum.polkaudio.com/discussion/143221/my-new-to-me-sda-srs-3-1tl/p1; http://audiokarma.org/forums/index.php?threads/polk-question-model-srs-31tl.463198/#post-6004063)
    <3 my 3.1TLs
    I will fix your shifted magnets for free. :)
    F1nut Posts: 51,858
    The problem with using an RCA pin is it's not a snug fit.
    F1nut Posts: 51,858
    pxm wrote: »
    -pxm
    If you are bridging stereo amps to mono blocks, think twice as that raises the noise floor. Regardless, you will get better sound quality by using the Dreadnought verses the standard SDA cable connection. There is a group buy going on right now, get in on it before 1/3/17.
    Link: http://forum.polkaudio.com/discussion/175325/group-buy-16-dreadnought-avel-lindberg-1000va-isolation-transformers#latest
  • Schurkey
    Schurkey Posts: 2,122
    edited January 2017
    "Grounded Bridge"? Isn't that a Crown patent for a PA/pro amp?
    1. If the negative terminal is connected to chassis ground, and this is a monoblock amplifier pair, you still need to strap the two chassis together or it isn't common-ground. I am NOT an Electrical Engineer, but I have a bad feeling about that. My rule-of-thumb is that bridged amps cannot be made common-ground; but that may or may not apply in this case. Be Careful.
    2. A typical "RCA cable" has a teeny-tiny conductor, while the OEM SDA cable conductor was either 16 or 18 gauge; and most here prefer still-heavier cable. Seems to me that someone claimed that some interconnect cables actually do use a heavy conductor, but I've forgotten the details. Be Careful.
  • pxm
    pxm Posts: 4
    -they are grounded bridge monoblock Crown M600's -i have them rack mounted in the same metal rack so they share a common ground. -i havent had any issues with a ground loop or feedback / hum in the 25 years ive owned them so i havent had the need to isolate one of the ac plug ground prongs yet etc...
    -im going to modify a P type twin blade connector that fit my sda-srs's as they have the same basic pin placement as the 3.1's for starters ...
  • Schurkey
    pxm wrote: »
    The problem is not ground loop/feedback/hum, and the fix isn't to destroy the safety grounding via the AC plug ground prong. That's an ENTIRELY DIFFERENT set of "grounding" problems.
    The problem in this case is the effect on sound quality having excessive resistance between the negative terminals of the amplifers creates. 20 ohms between the left and right negative terminals on my stereo amplifier made my 1Bs unlistenable. Other amps, other speakers can cause physical damage to speakers, or amplifier(s), or both. Do yourself a favor, plug an ohmmeter across the negative terminals of your two amplifiers, and report back on the resistance you measure. I bet there's several ohms. Steel is a crappy conductor.
    No resistance = good times.
    F1nut Posts: 51,858
    Oh boy!
  • vcwatkins
    vcwatkins Posts: 1,992
    IMO you'd be better off in the long run to build a Dreadnought using Neutrik connectors as F1Nut has suggested. There's a good chance it'll be yearsss before another 1000VA group buy happens if at all.
    However, if it's helpful, I have a pin/blade SDA cable I'm willing to part with for $40 shipped Priority Mail CONUS, Paypal gift. Not sure but I'm guessing it's 20' long.
    Craig
  • pxm
    pxm Posts: 4
    -they share a common ground as the resistance was ~ 0 ohms...
    -i have both the sda-srs's and the 3.1tl's interconnected now -quite an improvement...
  • Schurkey
    Pleased to hear Grounded Bridge amps are usable with SDAs. I wouldn't have guessed that. I'm also surprised that you don't have ~5 ohms resistance between the two amps.
    As said, "no resistance = good times."
  • maxd
    maxd Posts: 3
    New to posting on the forums but reading for a long time. Bought a Polk 3.1 tl today but no interconnect cable. I saw this cable which appears to have the speakon connector already on -https://www.amazon.com/18-Foot-Speaker-Terminated-Connectors/dp/B01DBS1DLC/ref=sr_1_23?s=electronics&ie=UTF8&qid=1517021336&sr=1-23&keywords=Canare+4S11+speakon . Will this be good for an interconnect. I am using a common ground parasound a23 to amplify.
    Viking64 Posts: 7,577
    maxd wrote: »
    Unless you already have aftermarket Speak-On connectors on your terminal plates, this won't work, obviously.
    If you do already have that upgrade, you would need to make sure that the connectors on that cable are compatible with how the connectors are wired on your terminal plates.
    If you are planning to upgrade to Speak-On connectors soon, make sure to do plenty of research via related threads on this forum as there are specific requirements necessary as to type of Speak-Ons (number of conductors, airtight characteristics, etc.).
    I'm sure others who are more-knowledgeable than I am will chime in.
    pitdogg2 Posts: 27,125
    Pretty much nailed it
    About others being more-knowledgeable? Yeah, I have come to accept that. :p
  • maxd
    maxd Posts: 3
    Thank you very much for that. I was wondering but the explanation was very concise. Found a pin connector on ebay for polk interconnect so will try that as my understanding on the 3.1 tl is that the blade is for support (not function). Then onto any other extensive upgrades. Much appreciated.
  • Schurkey
    The blade functions when the AI-1 is used. I wouldn't say it's for "support (not function)."
    The blade is the ground connection for the AI-1 (or Dreadnought) if the original connectors are used.
    edited January 2018
    The blade is only for support on ALL pin/blade models UNTIL you use non-common ground amps or monobloc amps. Only then does it becomes more than support.
  • TNTsTunes
    TNTsTunes Posts: 751
    The blade links the grounds together between both speakers for the SDA effect. That is it's function.
    When using a common ground amp the SDA effect still functions without it because they are common ground. The SDA ground has to follow the path threw the speaker cables and amplifier if you are using a cable without the blades connected.
    The AI-1 (or Dreadnought) is required to provide the SDA ground path to avoid damage when using a non-common ground or monoblock amplifiers.
    "Make a man a fire and he'll be warm for a day. Light
    a man on fire and he'll be warm for the rest of his life."
  • maxd
    maxd Posts: 3
    Ahh got it. I will be using the Parasound A23 which is common ground. But if there is a another Dreadnought buy, may get into it. I am still in the early phases of my audio journey and every 2 years the bug comes to dive deeper..I am hoping to upgrade the srs over time and then determine if I need to get something different..I appreciate all the valuable insights .
