Iphone Phone Question
boston1450
Im phone stupid...... This dang thing has been popping up on my phone FOREVER & i just keep hitting ok - because it pops up when i gotta use the iphone. Well today i finally read it for the 1st time ever
Well "while scratching my head" i have No Idea wtf this is..... Does this mean i gotta go to the phone store & wait in line or take a number. This could turn out to be worse than going to grocery store... Any idea what this is & do i need to go to at&t ?
Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
MIT BJC Cs1000p Polk Rotation
by David WMG
Randy-Maine
by David WMG
I plug the dang thing in every night. I keep going i will have hit the OK button a zillion times in the last year
Randy-Maine
by David WMG
No.35 mins away. At&t is close. Last time i went it was a nightmereRandy-Maine
by David WMG
Back it up manually to your computer using iTunes.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Thanks. I will have daughter do that. I will look at settings too. I also need to do the update i got months ago. Im a slackerRandy-Maine
by David WMG
You could try backing it up.
Three 20 amp circuits. -
boston1450 wrote: »Thanks. I will have daughter do that. I will look at settings too. I also need to do the update i got months ago. Im a slacker
Hey Randy, you don't need to do every update Apple throws your way. Same with apps updates. As your device ages, upgrading the apps and OS can potentially degrade the device performance.I disabled signatures. -
If you're not using icloud then I'd just turn it off. Then you won't get that message. That's what I do. Or at least turn off the icloud back up.Music: Oppo103 - Parasound JC2 - Parasound A21- SDA 3.1
Theater: Denon 3808 - B&K 7500/Emotiva XPA-3- RTi12, CSi5, RTiA7x4, PSW505
Sleeping: Marantz 70005 - Harman Kardon 2400 - SDA 2
2 Channel: Cary 306 SACD - Canary Audio 906 - Pass Labs x250 - PS Audio Perfectwave DAC, Polk LSiM705, SVS SB13 Ultra
Office: Dell Optiplex, Emotiva XDA-2, Adcom 5500, LSiM 703
Spares: Yamaha CA-810; LSi 15; Kenwood Basic M2a, Yamaha M60/M80, Polk Monitor 7, SVS SB13 Ultra -
Also...go to Settings ->iCloud and look at Storage. Does it say you have space available?No excuses!
My daughter is gonna swing by & fix it. That only pops up 3-4 time a week. I just keep pressing ok & pay the bill. Phone works great otherwise. Thanks guysRandy-Maine
by David WMG
