Iphone Phone Question
Im phone stupid...... This dang thing has been popping up on my phone FOREVER & i just keep hitting ok - because it pops up when i gotta use the iphone. Well today i finally read it for the 1st time ever :) Well "while scratching my head" i have No Idea wtf this is..... Does this mean i gotta go to the phone store & wait in line or take a number. This could turn out to be worse than going to grocery store... Any idea what this is & do i need to go to at&t ?
Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
MIT BJC Cs1000p Polk Rotation
  • boston1450
    boston1450 Posts: 7,758
    Randy-Maine
    by David WMG
  • boston1450
    edited December 2016
    I plug the dang thing in every night. I keep going i will have hit the OK button a zillion times in the last year :)
    Randy-Maine
    by David WMG
  • boston1450
    No.35 mins away. At&t is close. Last time i went it was a nightmere
    Randy-Maine
    by David WMG
  • vmaxer
    vmaxer Posts: 5,122
    Back it up manually to your computer using iTunes.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • boston1450
    Thanks. I will have daughter do that. I will look at settings too. I also need to do the update i got months ago. Im a slacker
    Randy-Maine
    by David WMG
  • BlueFox
    BlueFox Posts: 15,250
    You could try backing it up. :)
    msg Posts: 10,627
    boston1450 wrote: »
    Hey Randy, you don't need to do every update Apple throws your way. Same with apps updates. As your device ages, upgrading the apps and OS can potentially degrade the device performance.
  • Legender
    Legender Posts: 478
    If you're not using icloud then I'd just turn it off. Then you won't get that message. That's what I do. Or at least turn off the icloud back up.
    Music: Oppo103 - Parasound JC2 - Parasound A21- SDA 3.1
    Theater: Denon 3808 - B&K 7500/Emotiva XPA-3- RTi12, CSi5, RTiA7x4, PSW505
    Sleeping: Marantz 70005 - Harman Kardon 2400 - SDA 2
    2 Channel: Cary 306 SACD - Canary Audio 906 - Pass Labs x250 - PS Audio Perfectwave DAC, Polk LSiM705, SVS SB13 Ultra
    Office: Dell Optiplex, Emotiva XDA-2, Adcom 5500, LSiM 703
    Spares: Yamaha CA-810; LSi 15; Kenwood Basic M2a, Yamaha M60/M80, Polk Monitor 7, SVS SB13 Ultra
  • Strong Bad
    Strong Bad Posts: 4,278
    Also...go to Settings ->iCloud and look at Storage. Does it say you have space available?
    No excuses!
  • boston1450
    My daughter is gonna swing by & fix it. That only pops up 3-4 time a week. I just keep pressing ok & pay the bill. Phone works great otherwise. Thanks guys
    Randy-Maine
    by David WMG
