Sda srs 2.3 crossover question. Polyswitch.
bassfann
Just double checking. S1 is the location of the tweeter poly switch,correct ? I removed the PR and found the crossover dangling,held up by wire ties and electrical tape,I'm assuming (and praying),that this is not from the factory.
S1 is the location. The crossovers are normally attached to the large spool inductor with snap-in nylon standoffs.Home Theater/2 Channel:
dhsspeakerservice.com/ -
I know about the standoffs.I wonder why previous owner just hung them there,very sad. I soldered the joints together on the reverse side of the board to eliminate the switches.
