New TV prospects
My 65" ks8000 gets delivered tomorrow. Can't wait!
Quick update....Home Depot had 8M 45mm screws...only 3 of them. Identical to what came with my wall mount. Lowes had one, but it was 50mm. Since that one stuck out a hair, i used a 5/16 washer to really snug and secure it. Worked like a charm. TV is mounted perfectly.
I had the same issues mounting my 55 inch Insignia TV to my stand mount...the included bolts weren't long enough so I took one to work to find out what the size was and just took some of the wall. I work at an auto shop so we have extra hardware on hand for cars....figures Insignia would use a normal metric threaded bolt...win win.
Haha I hear ya. I use a VideoSecu mount. They had every possible size screw except this one. Then again, you had to use those mount adapters since the TV isn't flush flat in the back. So I guess it makes sense.
Sometimes a little DYI is all that it takes.
Marantz SR5011 / Polk Audio Signature S55 towers / Polk Audio Signature S35 Center/ Polk Audio Signature S15 surrounds / Velodyne DPS-10 / Samsung 60" KS8000 / Samsung UBD-K8500 -
So after a day of tinkering testing, etc. I'm exchanging the TV for a different unit. I know edge lit TVs naturally suffer from light bleeding (and it varies from TV to TV), but it was absolutely abysmal on this TV. So bad, that not only were the corners bright, but it was bleeding onto the picture itself. Darker scenes were unwatchable in certain aspects.
I've had other TVs in the past suffer from major light bleed, exchanged them for a second same unit, and had hardly any issues. Here's hoping!Marantz SR5011 / Polk Audio Signature S55 towers / Polk Audio Signature S35 Center/ Polk Audio Signature S15 surrounds / Velodyne DPS-10 / Samsung 60" KS8000 / Samsung UBD-K8500 -
What do you have the backlighting set to? From what I read,
10 seems to be the magic number to prevent this. -
Had it at ten, went down to 4 / 5 and was still there big time. Thing is, it's ALL over the place lol. Picture doesn't do any justice. It's worse in person.
We'll see if my exchange is any better.Marantz SR5011 / Polk Audio Signature S55 towers / Polk Audio Signature S35 Center/ Polk Audio Signature S15 surrounds / Velodyne DPS-10 / Samsung 60" KS8000 / Samsung UBD-K8500 -
I've seen that issue with Samsung and Sony. It seems like it's luck of the draw with some of the panels.
One of the reasons that the 65" version of my TV that changed to an IPS panel was rated so much worse. Many people got bad units and had serious light bleed issues.
If you get a good unit, they are awesome. Can you ask the store if you can open the box in the store and check for light bleed before you bring it home? -
Well, I got home with the replacement, hooked it up and ran some tests. Near perfect. Hardly ANY bleeding or flooding whatsoever except for the extreme corners butneven that's not too noticeable.
2nd time was a charm.Marantz SR5011 / Polk Audio Signature S55 towers / Polk Audio Signature S35 Center/ Polk Audio Signature S15 surrounds / Velodyne DPS-10 / Samsung 60" KS8000 / Samsung UBD-K8500 -
Upstatemax wrote: »I've seen that issue with Samsung and Sony. It seems like it's luck of the draw with some of the panels.
I qas legitimately thinking about that, but it's so damn bright in the store. I bit the bullet, took it home and it was much, much better.Marantz SR5011 / Polk Audio Signature S55 towers / Polk Audio Signature S35 Center/ Polk Audio Signature S15 surrounds / Velodyne DPS-10 / Samsung 60" KS8000 / Samsung UBD-K8500 -
Samsung uses a variety of different panels, some worse than others and sometimes within the same series. This is why when you buy a Samsung at discount stores like Walmart, your rolling the dice on the panel you'll get. Most brands have certain series that they specifically make to a retailers price requirements.
A little clouding on edge lit TV's is normal, that pic you posted was horrendous. Some of the worse I've ever seen. You can google up the better Samsung panels and also the ones to stay away from and which series they are in. As a rule of thumb, stay away from the off numbered series, these TV's are specifically made for certain retailers thus the shortcuts are incorporated to match the price required.HT SYSTEM-
lsi 9's -
Oh I absolutely agree. I always buy my TV's at Best Buy. I would never, ever buy at Walmart, Target or Costco. Heck, I wouldn't even order a TV online. Best Buy can now price match Amazon and Crutchfield (and they've done so for me within the past few weeks on other items), so there's really no need to shop anywhere else other than Best Buy, which I have two that are local.Marantz SR5011 / Polk Audio Signature S55 towers / Polk Audio Signature S35 Center/ Polk Audio Signature S15 surrounds / Velodyne DPS-10 / Samsung 60" KS8000 / Samsung UBD-K8500 -
I guess it depends on the store. They all vary depending on management. I've personally had some less than stellar experiences at my local Best Buy stores. I've since been using Crutchfield for YEARS now.
I have had nothing but amazing service from them. I've personally ordered 4 TV's from them and I have yet to have one issue (knock on wood!). When I get good service from somewhere, I become VERY loyal. Even if they don't have the lowest price, I'll still buy from them for peace of mind.
Honestly, just to avoid the mall, I think I'll stick with Crutchfield! haha.
I'm glad they are more flexible with price matching now though. Despite the fact I'm not a fan of them, them shutting down would not be a good thing for consumers.
I just ordered the KS8500 version for my daughter from Crutchfield.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Well we will be setting the TV up today. Any advise on the settings? It will be a while as we have to completely rearrange her bedroom then wall mount it but will get there.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Got the new TV mounted last night ....finally.
Out of the box the picture is awesome. My daughters boyfriend was here helping so as soon as we got it connected and went through the basic settings necessary to use the TV they wanted to play on the PS4.
I really like the picture but will adjust the settings and see what that does, but very happy with the picture as is. Awesome TV for sure.
I plan to start with the settings from here:
http://www.rtings.com/tv/reviews/samsung/ks8500
Thanks @DSkip for posting the link!!Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
OK those of you with the Samsung KS series sets. I have yet to get mine looking good with live sports, namely football. Everytime there is a switch back to live action from a replay, I get a second or two of very noticeable judder before things look normal. Have been playing with various settings to no avail. Anyone else see this? I'm not convinced it's the TV's fault as my hi-def cable box is ancient. If you've seen this, what setting changes did you make to fix it?
Yes it is more or less your cable box. I have Cox and had problems with their boxes. took like 3 or 4 exchanges before I got a good one. Still need to give it the unplug every now and then.. It's caused more or less from all the junk they add to the signal to keep people from trying to get free cable.When I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
