New speakers or not?
I have a set of rta15tl speakers that I have had since new. The tweeters are blown so I have them unhooked and have an old set of bookshelf speakers wired in that set on top for my highs. The sound it marginal at best. I am either going to replace them with a set of 75t's or 70 series ll. Or try to make the Rta 15tl's sound good again with a new set of tweeters. Not sure if I want to put the time and money into the old ones if they are not going to sound as good as a new set. Would like to get some opinions please.
Best Answers
  • Nightfall
    Nightfall Posts: 10,083
    edited December 2016 Answer ✓
    No comparison, you can fix your RTA-15TL's for $100 and they'll sound way better than dropping $200 on the speakers you're looking at.
    Unless you're in Colorado. In that case I'll buy you the 75t's and you give me the RTA's. ;)
    afterburnt wrote: »
    Village Idiot of Club Polk
  • NotaSuv
    NotaSuv Posts: 3,871
    Answer ✓
    Well worth fixing for twice that......never a reason to go backwards in sound quality
Answers
  • cfrizz
    cfrizz Posts: 13,415
    I'm planning on finally letting go of my RTA-8Ts in Feb. to get the new S60 Signature Series speakers. You might want to take a look at them, or the S55s.
    Talk to Dskip about them, he has a whole set in his house.
  • macntrent
    This will be the third set of tweeters that I will be replacing on the speakers since new. I wonder if there is a problem with the crossovers? When the tweeters were working and were at high volume they would shut down. They would come back on when I turned the volume down. I have had this problem since I bought them in 1990. The drivers have always worked well.
  • Nightfall
    Your amplifier isn't powerful enough to play your speakers at the volume you are. Turn it down or get a better amp.
    afterburnt wrote: »
    F1nut Posts: 52,173
    You are tripping the polyswitches (tweeter protection) because whatever you are driving them with is clipping at higher volume levels. So, what are you driving them with?
  • macntrent
    I am using a denon 5.2 channel receiver that is rated at 75 watts a channel at 8 ohms. Last receiver was a mid range Harman kardon.
  • cfrizz
    Yeah, that will do it for killing your speakers. You are over driving them because you don't have enough power to do so properly with just a receiver. If you have preouts, get an amp. Otherwise turn it down.
    F1nut Posts: 52,173
    Yep, severely under powered. As mentioned, add a power amp if possible otherwise get a high current integrated amp or separates. You'll be amazed at how much better they will sound even at low volume levels.
  • macntrent
    My amp only has 2 subwoofer pre outs that I am using. I guess I will need either a new higher power receiver or a set of speakers that are a better match with my current receiver. I have 2 powered 12 inch subs that produce nice clean bass that sounds great. Maybe a nice set of Polk bookshelfs for the fronts.
  • Nightfall
    Setting your RTA-15TL's to "small" in the AVR setup menu.would free up some amplifier power.
    afterburnt wrote: »
