More speaker wire talk...
Joey_V
Wel wel wel....
So last night I actually had time to demo the wires better.
Ofc 12g vs Audioquest wel 12g.
Just to be sure that I wasn't hearing things I connected one wel to one speaker and one ofc to the other.
It was output symmetric meaning each speaker put out same db.
I went from one speaker to the next and just listened to 1 driver. The midrange driver.
And there was a significant reproducible difference. The wel was better for sure. The other sounded hazy and harsh comparatively.
The differences were so pronounced that I'd have no problem putting money on the line had someone really pushed me. I'll put whatever money on the line and I'd pick the wel everytime.
Then I switched back and forth to full wel vs full ofc.... I was really really trying to see if I was just hearing things because nothing would make me happier than to hear minimal to no differences and I could resell the wel and use that money for more gear...
My final thoughts?
I cannot believe it took me 8 years to listen to the crap spewed on this forum.
...Only to find it was actually true.
My final thoughts?
The sound difference is dramatic between cables. Happy to hear you're happy
I was more hoping I would not hear a difference and would just go back to cheapo land.Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
You have crossed the one way bridge into cable hell. Welcome.
Tell me about it Russ. Frick me...Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
(FWIW) expectation bias always seems to work in reverse for me
I spend money on stuff and it doesn't sound better enough for me to justify the money I spent.
Congratulations, Joey, welcome, and... Also, my condolences. I hoped for the same. Unfortunately, the changes are undeniable.I disabled signatures.
Hearing is believing Joey. All we ask is for open minds and open ears......AND no, you don't have to spend WEL kinda coin to hear the differences either.
My argument to you Joey, and no offense brother, but you have had some nice gear over the years, imagine you may have kept a piece or 2 if you had decent cables hooked up to them. Just sayin'....because you never know the full potential until you marry a piece with the right cables.HT SYSTEM-
lsi 9's -
Yeah that's kinda what I was also thinking but ... I guess I wasn't ready to spend the coinMagico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
A too far open mind leads to brains on the floor.
Jay
rednedtugent wrote: »A too far open mind leads to brains on the floor.
I agree to thisMagico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
An open mind leads to an open wallet.
An open wallet can be full.
An open mind leads to an empty walletMagico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
I think I'll have Chinese tonight.
I have beer.
rednedtugent wrote: »I think I'll have Chinese tonight.
Your fortunes are bountiful, dig deep into the rice bowl.Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
I honestly believe that you need to have some pretty decent gear in order to hear any difference with cables / wires / interconnects / cords.
I also believe that the room, the biggest component in your setup, has to be able to reveal these differences to you.
In other words, a lot of things have to come together for changes to be noticed with ease. I guess that's synergy. It takes a lot of trial and error to find what works best for you and what works best for you may not work at all for someone else.
Enjoy the music Doc
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
I'm also low on beer, because I have hairy arms and drink bourbon.
Enjoy the music Doc
You speak some truth my friend, Victor.
Case in point:
My brother had brought home (from his dealer) some AQ, not sure which. Also brought home some cardas. Both about retail $2,000.
He plugged to his system, I asked him what he thought. His response? Difference heard, but not worth the cost.
Fast forward a couple years. We plug in the AQ Oaks into MY system ($3,000 retail)... we listened. First song - he says, "On your system, the cost differential is worth it. It actually makes a much bigger difference than on mine. I'd buy them if I were you."
And that's how this whole thing started. Once I heard AQ in my system, I talked with my other high end buddies and we discussed cabling... I always kept going back to AQ for what they stood for and what Bill Low's vision is. I guess I bought into the kool aid and I wanted to go balls out.
Then I found the WEL and the rest is history.
Btw, his system is BW804d2 and Musical Fidelity upstreams. Sounds pretty good actually. A little bright for me because I'm used to a much more rounded, analog sounding system.Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
Joey,
That may be an obscure case, the reality of the situation is.....every brand of gear or cables has a signature sound to it with different series of the brands carrying different versions of that signature sound.
The trick obviously, is trying to marry all those different sound signatures between pieces in your system, cables, speakers, to achieve the end result you desire. Easier said than done.
I like to get my ear on many things, that way I know roughly the sound signatures of many brands and the recipe I would need to achieve the results I want. Room not withstanding of course.
Many can't do that though, and some things in this hobby of ours requires a leap of faith, an educated guess, talking to people with ears you trust. That's how we move forward in our musical journey.
Glad to see the WEL's are playing nice with it's companions, and you. Just puts a smile on your face when you hit something that works well doesn't it ?HT SYSTEM-
lsi 9's -
I may be violating an explicit or implicit rule posting a link to another forum (if so, 1) I apologize and 2) please delete) -- but even I, cable agnostic that I am, found this thread (see link below) most amusing.
http://audiokarma.org/forums/index.php?threads/welcome-to-the-grand-illusion.745026/
Heck, even I know why one might make a "hollow core" cable -- I doubt that misrepresenting the cabling in question was the key motivation! -
mhardy6647 wrote: »(FWIW) expectation bias always seems to work in reverse for me
I hear ya! i definately have those momentsMain Rig:
Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
Second Rig:
Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded) -
Welcome to our world Joey, I still remember the day I got my hands on a pair of Transparent MusicWave Bi-wire cables and put them between my amp and the RTiA7s...it's like a whole new world to me at the time, now I run MITs on the SDAs...so much nicer.
I remember when I thought Monster cables were top notch
Main Rig:
Second Rig:
