Auralic Mini DAC/Streamer
Auralic Min wireless DAC/Streamer
After Taking to Luther about his I went ahead and bought a "Auralic mini" and was able to make a small size portable DAC/streamer to take on the go.
It cost $550 new and comes with a free year of Tidal (a $240 value) and you can put a inter SSD drive inside of it and you control with a apple device (either phone or IPAD) but the bigger IPAD is best to see the graphical interface. And it plays DSD files up to 5.6.!
Basic setup is easy I used my wireless router with internet connection to set it up and use it to stream tidal and do the firmware update it ask for, but I normally then switch to a cheap little wireless router without the net connection to use it in my 2 channel setup & the router is just needed to let the IPAD with the controlling software talk to the DAC to tell it what playlist and/or song to play next!
So now i have a small portable DAC/storage device with 1 TB SSD drive inside that is load with all my digital files like FLAC's and DSD hi-Rez files. no computer needed anymore and the MINI is only 5" x 5" with a nice small foot print. The reviews say if you buy the optional power supple to replace the included wall-wart the sounds SQ goes way up but so far it sounds really awesome to my ears with the wall-wart.
    How do you play Tidal without a computer connection ?
  • Joey_V
    Joey_V Posts: 8,603
    Do you know if this is better than the bluesound node 2 or the auralic aries?
    txcoastal1 Posts: 13,514
    tonyb wrote: »
    My Simaudio DAC/streamer also does Tidal natively
    That Aurilic mini is probably one of the next band for buck network streamer DAC, glad your diggin it
  • voltz
    voltz Posts: 5,384
    Tony, The Mini has Tidal built into the controlling software app used by the IPAD, so basically the IPAD is the computer.
    for Tidal to work I do have to the MINI/DAC & my IPAD both connected to my wireless router that has internet access.
    a wireless router is always needed to let the IPAD control it even when using just the internal SSD drive but the router does not have to have internet access - thus i can take it anywhere like to LSAF or someones else house :) but no TIDAL support without the web.
  • voltz
    voltz Posts: 5,384
    Joey , according to a review i read the Blue node 2 & the Mini are equal when the mini uses a external power supply and not the wall wart.
    but I have not personal heard the others to compare it with.
    EndersShadow Posts: 17,713
    Thats one slick SMALL setup. I always like simple setups like that.
    Problem is they all cost MORE money than I'm willing to invest lol...
  • erniejade
    erniejade Posts: 6,321
    I am actually testing out a blue node 2 right now. Tidal on it is slick. The Auralic is next on my list to check out since it does dsd and the bule does not.
  • marvda1
    marvda1 Posts: 4,954
    what if you don't have apple products(android)?
    Puritan PSM156
  • BlueFox
    BlueFox Posts: 15,250
    While I don't use it much anymore, my Auralic Vega DAC is a great price/performance product. However, it is old so I would expect a new version at some point.
  • voltz
    voltz Posts: 5,384
    marvda1 wrote: »
    There is no Android support right now and it doesn't seem like they are working on it either.
    I got lucky and my sister gave me her old IPAD one when she upgraded her's.
    You could steal Danny's >:) but he did have one for sale not long ago?
    And you have to have some apple product to use it's controlling software.
  • Wardsweb
    Wardsweb Posts: 942
    I love my Aries Mini. Have you seen when you turn the iPad one way you get all the information and when you rotate it 90 degrees it converts to all album covers?
  • voltz
    voltz Posts: 5,384
    I hadn't noticed that tell you mention it, as I had the screen-lock on.
    I did notice that if I click on a LP and started a song a little pic of the LP would be in the upper left corner and if I touch the little pic it would switch to a view showing all the songs on that LP and a bigger picture of the album cover and then if i clicked on the album cover again it show a large picture of it.
    just starting to get use to make playlist and how to search Tidal ...
    My sister who almost never touches my 2 channel setup as she won't play any vinyl and doesnt even like flippin CD's loves the MINI, and I catch her listen to my 2 channel setup more & more.
    She likes my CRS+'s over my Monitor 10's and said she hears a lot more stuff you can't hear on the 10's :p - had to explain how the SDA effect solves the 10's problem with Cross-talk ;)
    BTW Thank you Luther for steering me to the MINI! Kudos to You!!
    Think I may pick up the better power supply for it next.
