Question - how to rid of smoke/cig smell?
If working only with what is under the cabinet here I would go with white vinegar and warm water. Wipe down and let dry. Next trip through a hospital ask the head of housekeeping what they use to neutralize strong odors.
As an ex smoker......smoke is the absolute worst smell on the planet. I only hope public opinion turns on vaping as it did on smoking years ago, because both have negative health effects which will continue to drive up healthcare costs for us all because of the bad habits of a few.
Sweet dreams, Kev...... -
Right next to propane tanks no less, Russ likes to live on the edge.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
... I'm going to send my uncle. I will have him inspect and smell the cables. If it's good, then I'm going to hand over the cash.
And all this time we've been focused on the differences in sound... While he's at it, might as well ask him to give them a good lick, too. That ought to freak the seller out!
I will be shocked if you can perceive any smoke at all on an insulated jacket hiding in the corners of a non-smoking home. Its not like your buying a jacket or a sofa.When freedom is outlawed, only outlaws are free...
I detail friend's cars. Not professionally. But they have the same general plastics in them.
And to get rid of smoke odor it always takes more than one thing. First I shampoo and extract the fabrics in the interior. Then I use a special foam inside the air ducts, and finally I wipe down all the hard plastic with an automotive deodorizer.
But that is just the beginning. For the finale I get out the weapon of smell destruction.
The Ozone generator. I set the time for one hour and let in run in the closed car. Then I ventilate the car for a few hours with a fan blowing air through it. Then I give it the nose test. If any smell lingers I do the ozone treatment all over again. It always works.
For cleaning cables I would wipe them down with 409, then Windex, then put them in a plastic bag and have the ozone generator blow into it for an hour of so.
When done I toss them on the floor in front of a fan and let it blow fresh air on it for a week.
I have done this with Revox tape decks that spent their entire lives in a recording studio. And as I'm sure you know a recording studio is not a smoke free environment. -
Wait, you can smell your cables? Wipe em down with a cloth saturated with lemon juice. Ammonia is bad for copper.
This thread is much ado about nothing.Political Correctness'.........defined
President of Club Polk -
+1.
Three 20 amp circuits. -
Here at the Institute, we've been working along those very lines to develop a method for cleaning gear. Studies are almost completed.
Sal Palooza -
D a m n. The bottom teeth are better than mine.
mdaudioguy wrote: »... I'm going to send my uncle. I will have him inspect and smell the cables. If it's good, then I'm going to hand over the cash.
Hey! The seller recommended smelling the cables hahaJoey, buy em yet???
Almost... Until my uncle picks it up and hands over the cash... I dunno
But it's on hold as we speak
Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound -
Smoking does not drive up healthcare costs, nor does the lack of it reduce costs. If you believe that, kindly point to anything that says so. I think it's a pretty safe assumption to say we have less smokers today than 20 years ago and I never once experienced a reduction in HC costs. Matter of fact, just the opposite.
http://www.reuters.com/article/us-healthcare-costs-smoking-idUSKBN0JX2BE20141219
http://www.nejm.org/doi/full/10.1056/NEJM199710093371506?ck=nck&#t=article
https://www.ncbi.nlm.nih.gov/pmc/articles/PMC1360912/
http://www.cdc.gov/tobacco/data_statistics/fact_sheets/fast_facts/ -
FYI use this stuff it just melts nicotine off EVERYTHING. My dad smoked Camel cigs non filtered until he died. The rooms he was in were white.... While we did repaint some wouldn't stick even with kilz this stuff straight will make it run off the walls...
https://www.dollartree.com/20-oz-Totally-Awesome-Cleaner/p8056/index.pro
it can be bought at many places like wal-mart, Lowes and many others it works very well and will not fubar anything that i found yet.
guess it does have some here's what I found although it has no citrus smell what so ever.
http://www.menards.com/msds/110283_001.pdf -
My only worry about that is rubbing it on an expensive wire and since it has a braid...Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound -
was just curious. I love citrus cleaner for the effectiveness while still not being quite as harsh as something like Castrol Super Clean or Purple Power. I haven't worked enough with citrust to know how much they affect different surfaces, but that ZEP heavy duty citrus degreaser from Home Depot/Lowe's works really well for tough stuff, as well. something else to consider; test in inconspicuous area.I disabled signatures.
rubbing alcohol rub downOnkyo TX-NR636
Main - polkaudio Monitor 60's
Center - polkaudio CSI A6
Sub - polkaudio PSW10
Sub2 - polkaudio PSW505
Surrounds - polkaudio Monitor 40 series II
Front Height - polkaudio Monitor 40's
Audio Outdoors
Pioneer VSX 406 - polkaudio Atrium 5
Shed
Sony junker str-dn2010 with Sony bookshelf floor models and polkaudio R150's
Shed 2
Nakamichi soundbar -
geesh you could put some baking soda on a cookie sheet lay cables on top put bag over and stick in a freezer take out in couple off days should be nothing.
always worked for me.
looking back seems the cart is before the horse here..... -
What do you mean cart before the horse? You mean planning your moves before making a big purchase is a bad move?Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound -
Farts clear all the ambient air out for me...
My wife smokes outside not in the house. I've sent folks here cables some braided, not once did anyone mention that because they didn't smell like smoke.
I understand apprehension for a large purchase but I'd be compelled to believe the seller until proved otherwise. Most folks with quality gear of that magnitude tend to be pretty legit I'm my experience. -
That's what I hope for tooMagico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound -
ken brydson wrote: »Farts clear all the ambient air out for me...
UhhhhMagico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound -
Shoot, I've got it. Just change the baby's diapers in the room and keep the diaper genie in there too. After a couple days you'll wish you could smell the smoke
Brilliant....thinking outside the box.HT SYSTEM-
