Does number of copper wire strands matter? Hard to gauge?
Well, the pass through does not work on the new AVR. Severe handshake issue.....ughMarantz SR 5010
Kenwood DR-V5070
Polk RTi A9- Mains
CSI A6- Center
Elemental Designs A2-300 Subwoofer
Panamax M4300-PM Power Conditioner
Working on updating my set up :rolleyes: -
Severe handshake issue... I like that.
I think Howard Hughes had that problem in the later years of his life ;-)
Shoe size issue also. Getting old, but with lots of money, has many problems.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Yeah, well, when one's toenails are six or eight inches long...
If connecting your LCR and the BPs are robust enough, go for the BJC 10 ga - those channel's bass will thank you for it.
More later. Leaving for churchSamsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
*all connected w/Premiere ICs
4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
Mario Andretti - "in racing, experience isn't everything. It's the only thing." For bass response/extension & dynamics in audio, gauge* isn't everything. It's the only thing.Dennis Gardner wrote: »...Gauge is measured in total, so for the current it really doesn't care.
* & large surface area/tight connections
Go big or go home.
Tony
Well, it seems my output settings on my cable box were not right. I adjusted it and the AVR it now working.
Marantz SR 5010
Kenwood DR-V5070
Polk RTi A9- Mains
CSI A6- Center
Here are my home made cables, AQ 16/4, all 4 wires per channel, AQ silver plated copper nanners. So each speaker has 2 separate cables.
Seems to work pretty well for me, huge improvement over the 10 gauge I had been using (I don't remember the brand, it was just some cheap wire someone on here gave me, worked great when it was all I had)2 Channel(work in progress):DAC: Schiit modi 2 uberAmp:Parasound 1200 MK IISub:RBH 1010-SEP Speakers: Monitor 5A peerlesscurrently running some krk rokit 3g since the HK pre outs died and i need to start breaking everything down to move in a couple monthsHeadphones:Source: tidalDAC: schiit modius epre: schiit sysAmp: AQ dragonfly black/ schiit magni2 Cans: Velodyne V-True, Grado SR225i, sennheiser x drop gaming headsetPC:DAC: schiit modius e(over spdif)pre: schiit sysspeakers: prenous eris 5 xtSub: Earthquake Sound MiniMe-P63most of my comments are passing on of info, im a noob, im just trying to help how i can, if im wrong or out of place to comment, dont hesitate to let me know
"WITH WILLING HEARTS AND SKILLFUL HANDS, THE DIFFICULT WE DO AT ONCE, THE IMPOSSIBLE TAKES A BIT LONGER, WITH COMPASSION FOR OTHERS. WE BUILD - WE FIGHT FOR PEACE WITH FREEDOM"Seabee Memorial, Arlington, VA -
They were easy to build, I got the pugs with the set screws. I know you'll love what you went with, I had some sewell plugs for a wire, made for easy set up, but didn't sounds as good as my naks or bare wire.2 Channel(work in progress):DAC: Schiit modi 2 uberAmp:Parasound 1200 MK IISub:RBH 1010-SEP Speakers: Monitor 5A peerlesscurrently running some krk rokit 3g since the HK pre outs died and i need to start breaking everything down to move in a couple monthsHeadphones:Source: tidalDAC: schiit modius epre: schiit sysAmp: AQ dragonfly black/ schiit magni2 Cans: Velodyne V-True, Grado SR225i, sennheiser x drop gaming headsetPC:DAC: schiit modius e(over spdif)pre: schiit sysspeakers: prenous eris 5 xtSub: Earthquake Sound MiniMe-P63most of my comments are passing on of info, im a noob, im just trying to help how i can, if im wrong or out of place to comment, dont hesitate to let me know
