Does number of copper wire strands matter? Hard to gauge?
  • Poolgod69
    Poolgod69 Posts: 184
    Well, the pass through does not work on the new AVR. Severe handshake issue.....ugh
    Marantz SR 5010
    Kenwood DR-V5070
    Polk RTi A9- Mains
    CSI A6- Center
    Elemental Designs A2-300 Subwoofer
    Panamax M4300-PM Power Conditioner
    Working on updating my set up :rolleyes:
    mhardy6647 Posts: 35,041
    Severe handshake issue... I like that.
    I think Howard Hughes had that problem in the later years of his life ;-)
  • BlueFox
    BlueFox Posts: 15,251
    Shoe size issue also. Getting old, but with lots of money, has many problems.
    BlueFox wrote: »
    Yeah, well, when one's toenails are six or eight inches long...
  • gp4jesus
    gp4jesus Posts: 2,019
    If connecting your LCR and the BPs are robust enough, go for the BJC 10 ga - those channel's bass will thank you for it.
    More later. Leaving for church
    *all connected w/Premiere ICs
  • gp4jesus
    edited October 2016
    ...Gauge is measured in total, so for the current it really doesn't care.
    Mario Andretti - "in racing, experience isn't everything. It's the only thing." For bass response/extension & dynamics in audio, gauge* isn't everything. It's the only thing.
    * & large surface area/tight connections
    Go big or go home.
    Tony
  • Poolgod69
    Well, it seems my output settings on my cable box were not right. I adjusted it and the AVR it now working.
    Marantz SR 5010
    Kenwood DR-V5070
    Polk RTi A9- Mains
    CSI A6- Center
  • seabeerob213
    seabeerob213 Posts: 1,843
    edited October 2016
    Here are my home made cables, AQ 16/4, all 4 wires per channel, AQ silver plated copper nanners. So each speaker has 2 separate cables.8c9wsftoc1ln.jpg
    Seems to work pretty well for me, huge improvement over the 10 gauge I had been using (I don't remember the brand, it was just some cheap wire someone on here gave me, worked great when it was all I had)
  • seabeerob213
    They were easy to build, I got the pugs with the set screws. I know you'll love what you went with, I had some sewell plugs for a wire, made for easy set up, but didn't sounds as good as my naks or bare wire.
