I got the itch....
For some Rogue gear....tubed separates. There is something about gear made in the USA which appeals to me, since everything these days is made offshore. I'm thinking a used Atlas magnum amp and Metis magnum pre.....or possibly a Pharaoh integrated. Any Rogue experiences out there to share folks?
  • lightman1
    lightman1 Posts: 10,797
    I've got a Magnum 66. I've never laid eyes on it. Bit I have one, none the less.
    @sketchycraig...... B)
  • Joey_V
    Joey_V Posts: 8,603
    I've had a couple Rogue products before. I thought they were pretty good.
    nooshinjohn Posts: 26,006
    If looking for tube amps, the Carver 305's can be had for a great price on the used market
  • kharp1
    kharp1 Posts: 3,453
    I got the itch....
    Too bad there's not an ointment cream you can get to cure that, would be a lot cheaper than "feeding the monkey."
  • kharp1 wrote: »
    I got the itch....
    I am with you, I bought 2 amps I really did not need this weekend, although I am going to keep one because it is awesome. Now I need to sell the one it replaced and the other that failed the audition. My monkey is so bad for tying up so much money I had to spank it.
  • Dawgfish
    Dawgfish Posts: 2,554
    Have a Rogue 88 Magnum amp. Love it!
  • Faustin
    Faustin Posts: 1,151
    Had a Silk Audio (Yaqin) MC 100 for about a year that in my opinion did not pair well at all with my SDA 1c's. Sold that and tried a used Jolida JD1000. Within 2 weeks I returned that. There was nothing I liked about it. Now have a Rogue Cronus Magnum II that I really like. Pairs well with the 1c's. It still needs some burn in time, but I am happy with it. I am sure at some point I will get the "itch" again and will want to try separate tube gear.
  • kevhed72
    kevhed72 Posts: 5,170
    Faustin wrote: »
    The Cronus Magnum is also on the list, since they can be had easily on the used market. How much heat does the thing give off....out of curiousity
  • Faustin
    I don't think the Cronus Magnum puts out anymore heat than the other 2 amps I had. Next time I have it on I will try to check the heat level around it.
  • GlennDog
    GlennDog Posts: 3,158
    I'm very pleased with my M-180 monos.
    The only drawback is in the summer . . . 8 KT120s generate a lot of heat!
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
