I got the itch....
kevhed72
For some Rogue gear....tubed separates. There is something about gear made in the USA which appeals to me, since everything these days is made offshore. I'm thinking a used Atlas magnum amp and Metis magnum pre.....or possibly a Pharaoh integrated. Any Rogue experiences out there to share folks?
I've had a couple Rogue products before. I thought they were pretty good.Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
If looking for tube amps, the Carver 305's can be had for a great price on the used marketThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
I got the itch....
Too bad there's not an ointment cream you can get to cure that, would be a lot cheaper than "feeding the monkey." -
I got the itch....
I am with you, I bought 2 amps I really did not need this weekend, although I am going to keep one because it is awesome. Now I need to sell the one it replaced and the other that failed the audition. My monkey is so bad for tying up so much money I had to spank it.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
Idolizing a politician is like believing the stripper REALLY likes you. -
Have a Rogue 88 Magnum amp. Love it!
Had a Silk Audio (Yaqin) MC 100 for about a year that in my opinion did not pair well at all with my SDA 1c's. Sold that and tried a used Jolida JD1000. Within 2 weeks I returned that. There was nothing I liked about it. Now have a Rogue Cronus Magnum II that I really like. Pairs well with the 1c's. It still needs some burn in time, but I am happy with it. I am sure at some point I will get the "itch" again and will want to try separate tube gear.
The Cronus Magnum is also on the list, since they can be had easily on the used market. How much heat does the thing give off....out of curiousityHad a Silk Audio (Yaqin) MC 100 for about a year that in my opinion did not pair well at all with my SDA 1c's. Sold that and tried a used Jolida JD1000. Within 2 weeks I returned that. There was nothing I liked about it. Now have a Rogue Cronus Magnum II that I really like. Pairs well with the 1c's. It still needs some burn in time, but I am happy with it. I am sure at some point I will get the "itch" again and will want to try separate tube gear.
I don't think the Cronus Magnum puts out anymore heat than the other 2 amps I had. Next time I have it on I will try to check the heat level around it.
I'm very pleased with my M-180 monos.
The only drawback is in the summer . . . 8 KT120s generate a lot of heat!AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12
