Speaker Stands
halo
halo Posts: 5,616
Has anyone ever tried speaker stands with Floorstanding / Tower loudspeakers?
Some of the higher end speakers out there are quite tall. I'm also pretty tall when sitting and listening, definitely taller than the height of the tweeters.
Aside from stands, what about tilting or adjusting the rake of the speakers?
I'm curious to know what other members have done to get the teeters of their towers at eat level and if there's a difference in sound quality.
Will there be any tradeoffs in doing this?
Thanks in advance!
    mhardy6647 Posts: 34,996
    edited August 2016
    umm -- yeah :)
    9606201717_d3fb6c6688_z.jpgearlypolkfamilyportrait by Mark Hardy, on Flickr
    For towers, tilting can be a bit... fraught (as they say nowadays... as in "fraught with terror"), but there can still be some value in decoupling from the floor (yeah, yeah there are other ways to do that, of course) and in some cases, raising the MR/treble drivers to ear level.
    Here's a quick & dirty example with a pair of Mirage L-750s. I refoamed the woofers on these for the fellow who built our house :) I tried them on (EDIT) a pair of commercial stands that were sitting around. It fixed a certain bass-heaviness... but looked terrifying, so I cut up a couple pieces of pine board to make some experimental stands, which worked OK (fit for purpose).
    24140001459_117f162f21_b.jpg001 by Mark Hardy, on Flickr
    EDIT: I guess I don't have a photo of 'em on the low-riser stands I made :(
    FWIW, I stick pretty much everything on stands when I audition loudspeakers...
    15940929034_fa573ba218_b.jpgDSC_0184 by Mark Hardy, on Flickr
    15963401893_0905494269_b.jpgDSC_3316 by Mark Hardy, on Flickr
    24741722432_b8153ab13e_b.jpg085 by Mark Hardy, on Flickr
    24169069713_3502aa9491_b.jpg004 by Mark Hardy, on Flickr
    18273630709_b6366d05a3_b.jpg049 by Mark Hardy, on Flickr
    No stands for these, but they're designed to put the drivers at ear level. They are standing on some hockey pucks, tho'.
    26171358706_2784026da9_b.jpg077 by Mark Hardy, on Flickr
  • Joey_V
    Joey_V Posts: 8,600
    Read up on the masters set up process. Tilting is the last step in the set up.
  • halo
    halo Posts: 5,616
    Joey_V wrote: »
    I saw a video on it. Very interesting. Not an equilateral triangle between the main speakers & the listening position
  • steveinaz
    steveinaz Posts: 19,545
    Eliminating toe-in would probbaly render similar results.
  • halo
    halo Posts: 5,616
    steveinaz wrote: »
    Hi Steve.
    Similar results as placing them on stands or something else? I don't have them toed in.
  • halo
    halo Posts: 5,616
    DSkip wrote: »
    Toe in will affect the frequency response as you get more off axis. Tilting will have similar results but to a much lesser degree. Tilting will also align the tweeter and woofer a bit better if done correctly.
    Thanks Skip :)
