RCA CAPS
mantis
mantis Posts: 17,374
Hello all,
Awhile back when I purchased my SC-99, Endershadow pointed out that the Audioquest RCA caps actually can make EMI RF interference worse then if they where not there.
Now I heard his words but until right at this very minute I have not researched this issue either way.
I have not done any listening with them on and then off. My receiver is basically completely covered with them. All unused jacks have them on except a few which I was going to purchase more but His words stuck in my head enough not to buy more.
So my question to you guys since I haven't done it myself is has anyone researched this or tested it on their system?
I'm curious as I love the fact that they are supposed to keep noise down and they keep all unused jacks clean. I might like the clean better as I don't think I have any RF or EMI issues in my system. I'm completely anal about wire management and using high quality cables. My entire system is Audioquest.
Talk to me people
Dan
    msg Posts: 10,452
    if concerned about the interference but want to keep the connections clean, aren't there some rubber cap types you can use?
  • halo
    halo Posts: 5,616
    My P5 preamp came with silicone caps on ask the RCA jacks. I liked it. It looked clean and it was easy to see, at a glance, which inputs I was using. This was very helpful when trying out different interconnects. They're available on eBay for less than $10 in sets of 50 or 100. Some are black, white, red, yellow, or combinations. I saw 1000 on amazon for $15.
    I don't think that the silicone caps will affect sound quality at all.
    I know that shorting caps are available as well. It's a male RCA plug that you insert into the female jack. A little more bulky than caps but I'd imagine you'd have no noise from these being inserted in the Jacks that aren't being used.
    You can buy a set or, if you're handy, make them yourself and see what you do or don't notice. Try to get another set of ears in the set up with and without the shorting caps.
    I ordered a bunch of the silicone caps and I'll be using them for all my unused female RCA jacks.I'm bummed about the mess of cables behind my av rack. If I get any free time I may tackle that project.
    Good luck!
    gudnoyez Posts: 8,161
    My Vincent Preamp came with those cloudy colored plastic caps, they were a pita to get off. I left them on all unused Jack's and saved the ones I removed, how would the unused ones that are still on interfere with the sound?
  • halo
    halo Posts: 5,616
    edited August 2016
    gudnoyez wrote: »
    Were they hard plastic or flexible? Mine were soft and flexible & they very easy to remove and reinstall.
    msg Posts: 10,452
    I can't see how the plastic ones would interfere at all, Steve, so personally I'd opt to leave them on, unless replacing with the shorting caps. Are these the ones Dan's calling into question, though?
    I've had similar experience in removal. I'd recommend using something of rigid plastic, and not a screwdriver, to gently pry them off without scratching the jack.
    You can also cut small block of cheese to use as caps if you don't have any of the plastic/silicone ones handy.
  • halo
    halo Posts: 5,616
    F1nut Posts: 51,761
    I've been using Cardas caps for a very long time. I can't say I noticed a change in the sound one way or the other, but I do like the way they look. I can't see them creating a problem though.
  • FTGV
    FTGV Posts: 3,650
    edited August 2016
    The plactic caps are strictly for keeping the unused connector clean.The caps that short the center pin to ground are to prevent RFI intrution on that input.Since an open connection is basically an antenna grounding it will eliminate that path.As for it being audible my guess is not likely but would be highly dependant on the input design of the particular component.
  • mantis
    Rick88 wrote: »
    I have been wondering about these as well.
    I have been thinking about getting some caps to put on all unused RCA jacks on my NAD T758 and all of my other gear. I want to do this for appearance reasons mainly, and to keep dust out. For those reasons I am thinking about getting some of the rubber caps as they are much cheaper and would accomplish my goals. I'd get some in red and some in white to easy distinguish the left and right channels when swapping out gear.
    https://www.amazon.com/gp/product/B008MMVCY6/ref=ox_sc_sfl_title_4?ie=UTF8&psc=1&smid=A30WUG2ZDGM0XM
    Thinking into this topic, Rubber caps make total sense.
    Dan
  • mantis
    The Cardas caps are exactly like the Audioquest models.
    Dan
  • halo
    halo Posts: 5,616
    Rick88 wrote: »
    mantis wrote: »
    Rick88 wrote: »
    I am thinking about ordering 1,000 each of the red and white ones. I have to count how many I need, but obviously it is nowhere near that many. But if I order 2,000 I should have a lifetime supply. I'd probably even put some up for karma while I'm at it...
    Well, why don't interested parties pitch in and divide the # of caps equally?
    $5 for 250 caps? 125 white and 125 red? Count me in.
  • halo
    halo Posts: 5,616
    The ones I had were soft plastic or silicone. I ordered some black caps from eBay.
    The 1000 count from amazon would be about $30 for 2000 caps.
  • skrol
    skrol Posts: 3,449
    edited August 2016
    When I was working on one of my Parasound pre-amps I was trying to figure out why I was getting a buzzing noise on the output. Turns out that my overhead fluorescent light above my bench was emitting noise that was being picked up by the pre-amp. Using shorting caps on the unused inputs cleared it right up.
    Stan
    Main 2ch:
    HT:
    Other stuff:
    F1nut Posts: 51,761
    This would probably be a good time to mention, do NOT use shorting plugs on outputs as that could cause serious damage to your gear.
    msg Posts: 10,452
    Ha, I'm glad you mentioned that about the outputs. I'll admit, I didn't even think about it at first.
    tonyb Posts: 33,072
    nbrowser wrote: »
    Jesse, I'm fairly certain most here know better,)
    You can never be sure, but the mention is worthy.
    The way most flip gear around here though, does dust even have a chance to accumulate ? :)
  • skrol
    skrol Posts: 3,449
    Yes, unless you have short circuit protection; shorting the output of your amp may cause some buzzing, then a pop, and then smoke. After that your output will likely be very low noise.
    Stan
    Main 2ch:
    HT:
    Other stuff:
    pitdogg2 Posts: 27,040
    skrol wrote: »
    that's some funny snot right there ......LOL
    the magic smoke has left the building:)
  • mrbiron
    mrbiron Posts: 5,721
    nbrowser wrote: »
    Jesse, I'm fairly certain most here know better, except 16, 6, 2 (code used for obvious reasons...solve it...get a free LOL click from me! anyone can enter.)
    PFB!!! PFB!!! PFB!!!
    Me so hot right now....me solve you problems like butta!
  • FTGV
    FTGV Posts: 3,650
    edited August 2016
    The vast majority of preamp/line level outputs on modern gear will have some series output resistance.This will prevent a dead short from occuring even if one was to inadvertantly place a shorting link across the connector.But it's better to be safe than sorry.
    As for shorting the output of an amplifier that ofcourse would be BIG no no.However I'm not sure how one would accomplish that feat with an RCA cover :#
    F1nut Posts: 51,761
    nbrowser wrote: »
    You shouldn't go to the bank with that thought.
  • Nightfall
    Nightfall Posts: 10,084
    I Googled 16, 6, 2 and it brought up the police code in Georgia for sodomy.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • drumminman
    drumminman Posts: 3,396
    Why not use inexpensive rca plugs on the unused inputs? I did this using some parts express and Cardas left over from IC builds on a NAD pre with lots of inputs and I could hear an improvement. Not night and day, but a nice little tweak
    txcoastal1 Posts: 13,512
    Looks like images from the Valley of the Dolls
  • mantis
    Rick88 wrote: »
    mantis wrote: »
    Rick88 wrote: »
    I have been thinking about getting some caps to put on all unused RCA jacks on my gear. I want to do this for appearance reasons mainly, and to keep dust out. For those reasons I am thinking about getting some of the rubber caps as they are much cheaper and would accomplish my goals. I'd get some in red and some in white to easy distinguish the left and right channels when swapping out gear.
    Dan, did you (or anyone else) ever get some of the rubber caps?
    On December 28th I finally decided to order 1,000 each of the red & white caps. When I ordered them I didn't realize they shipped from China. They finally arrived today and I just finished putting them on all unused jacks of both my amps, and will put them on the rest of my gear in the next couple of days.
    It cleaned up the back of my amps a great deal, and I like knowing that no dust will be able to enter the RCA jacks now. It was well worth the small investment!
    I want to keep about 250 of each color for the future for myself, but over the weekend I'll start a thread to see who would like to get some of the remaining balance. I'll ask who wants any and how many, then figure out how much it will cost to ship them to you. I won't be looking to make a dime, just want to recoup the cost I paid for them and the USPS mailing fees. Stay tuned... B)
    Rick,
    No I have not. I have Audioquest ones but I wouldn't mind some of the Rubber ones. In my opinion it makes more sense for them to be rubber over metal anyway.
    Sign me up man and just let me know what I owe you for them. I'll take like 30 of each color or so or whatever you can spare.
    Dan
  • halo
    halo Posts: 5,616
    I got a small bag of twenty black plastic caps. Not expensive and they go on and come off very easily. Red & white would probably look nicer or all white but they serve the same purpose and I'm not back there looking at them so it's moot. lol.
    Rick88 wrote: »
    mantis wrote: »
    Rick88 wrote: »
    I'd be game for some Rick, Don't want to step on any toes so let me know when the dust settles. I'm not sure how many I need at the moment all me gear is in storage.
    Ivan
  • kharp1
    kharp1 Posts: 3,453
    I would be in for 20-30 of each.
  • kharp1
    kharp1 Posts: 3,453
    DSkip wrote: »
    Rick88 wrote: »
    I've got a lot going on right now so please be patient everyone.
    But I will sort this out over the weekend. B)
    C'mon Rick. At least charge enough to get a few beers out of this. The work alone dictates a 6 pack. I shipped about 9 packages the other day and it took me about 2 hours get it all prepped.
    Sounds fair to me.
    EndersShadow Posts: 17,704
    I ended up with these ones.
    https://www.ebay.com/itm/400813863894
    More because they are a HECK of a lot cheaper than either Cardas or Audioquest.
    They keep it looking clean and I had enough for almost all my connections in the HT.
    I will prob buy more for my loft soon for the Anthem.
    Does it sound better.... not sure but it helps my audiophile inner self sleep better at night :smile:
    I'd love to find some for the internal computer slots I'm not using, and maybe the other stuff like HDMI ports, etc. More for my OCD than anything.
