AES Paper: A Meta-Analysis of High Resolution Audio Perceptual Evaluation
vc69
aes.org/tmpFiles/elib/20160715/18296.pdf
I thought you guys might have some interest in this.
@DarqueKnight
@DarqueKnight
-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
Muscial Fidelity M1 DAC
VTL 2.5
McIntosh 2205 (refurbed)
B&W 801's
Transparent IC's
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
VTL 2.5
B&W 801's
Transparent IC's
author's commentary can be found HERE-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
VTL 2.5
B&W 801's
Transparent IC's -
Thanks. Didn't read it start to finish, but the gist is people can tell the difference between high-res, and CD quality music.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
It does state that if you're trained to listen then you can hear the difference
The reality is you must be familiar with the music in order to devise a comparison2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Thanks for the cliff notes fellas there is no way in hell Im going read all that.
Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant -
txcoastal1 wrote: »Thanks. Didn't read it start to finish, but the gist is people can tell the difference between high-res, and CD quality music.
Yes, it states if you are trained then you can better tell the difference, but even without training there still is a statistical difference in being able to hear a difference.
I figured DK would feel vindicated.
It's really not that bad of a slog (to read through) and summaries are made at the end of most sections.-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
VTL 2.5
B&W 801's
Transparent IC's -
Finally got around to reading this. A common characteristic of many of these type studies is that they do not directly relate to the stereophonic listening experience. This is particularly true with regard to listening to only snippets of a recording.
Some notable quotes:
"The results are striking. The training subgroup reported
an overall strong and significant ability to discriminate high
resolution audio. " p. 371
"The International Telecommunication Union recommends
that sound samples used for sound quality comparison
should not last longer than 15–20 s, and intervals
between sound samples should be up to 1.5 s [78], partly
because of limitations in short-term memory of test subjects.
However, the extensive research into brain response
to high resolution content suggests that exposure to high
frequency content may evoke a response that is both lagged
and persistent for tens of seconds, e.g., [22, 48]. This implies
that effective testing of high resolution audio discrimination
should use much longer samples and intervals than the
ITU recommendation implies." p. 371
"It is well-known that the dynamic range of human hearing (when measured
over a wide range of frequencies and considering deviations among subjects)
may exceed 100 dB. Therefore, it is reasonable to speculate that bit depth beyond
16 bits may be perceived." p. 372
"When subjects were trained, the ability to discriminate was far
more significant. The analysis also suggested that careful
selection of stimuli, including their duration, may play an
important role in the ability to discriminate between high
resolution and standard resolution audio. Sensitivity analysis,
where different selection criteria and different analysis
approaches were applied, confirmed these results." p. 373author's commentary can be found HERE
I laughed out loud when I saw that the first and only responder was someone who has been banned from numerous audio forums.Proud and loyal citizen of the Digital Domain and Solid State Country! -
Good point Ray, although I was expecting Jinjuku.Lumin X1 file player, Westminster Labs interconnect cable
Musical Fidelity Tri-Vista 300, Audioquest Thunderbird Zero Speaker Cable, Tyler Highland H2, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
