LSI9 weak tweeter response
Just picked up a pair of LSI9's and one of the tweeters output is weak.
I swapped them over and its not the tweeter so i pulled out the Xover but i cant see anything obviously wrong. No burnt resistors or caps. it all looks pretty good.
Anyone got some advice please?
Cheers
Brad
  • Braddles63
    Braddles63 Posts: 191
    I have also checked the jumpers and they are connected correctly.
  • codycatalist
    codycatalist Posts: 2,661
    I would measure the tweeter with a multi meter and see if it is still good. My SL2000 had a dull or weak output sound because it was blown. Not sure of what the measurements would need to read but im sure Polk CS could tell you.
  • Braddles63
    Thanks Codycatalist. Like I said I have swapped the tweeters between the speakers and nothing changes. So I'm assuming its not the tweeter itself. There is sound coming from the tweeter but its not extended like the other speaker. Its sounds muffled.
    F1nut Posts: 52,147
    You've got a bad resistor. You can't always go by appearance.
  • skrol
    skrol Posts: 3,480
    Good time tp do an xo upgrade
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • Braddles63
    Thanks guys. I will get some new caps.
