Tweeter problem but not polyswitch
jasonkodat
jasonkodat Posts: 2
edited October 2004 in Troubleshooting
Hello all,
I've searched a bit. My mids are fine. Both tweeters worked in the one speaker (they're Monitor 5's) but neither tweeter worked in the other speaker, so I called and ordered polyswitches. They came in and I opened up my crossover.
Voila, no polyswitch at all on my crossover.
Is there something else I can check or am I just better off replacing the whole crossover at this point?
Thanks,
Jason
Post edited by jasonkodat on
    F1nut Posts: 51,700
    edited October 2004
    Check the fuse on the binding post plate.
  • jasonkodat
    jasonkodat Posts: 2
    edited October 2004
    F1nut,
    The fuse was the first thing I checked since they're outside, and it didn't look blown, so I ignored it. It must've just been making bad contact, I swapped the fuses and now both tweeters work.
    <sigh> And to think I could have avoided pulling out all my hair just by doing one more swap... :)
    Thanks.
    F1nut Posts: 51,700
    edited October 2004
    Ah ha!
    I'm glad it was a simple fix. You might want to go back and clean the fuse ends (or buy new ones) and the clips really well. I'm sure they have plenty of oxidation after all these years.
  • Tour2ma
    Tour2ma Posts: 10,177
    edited October 2004
    Memo to self: Always check the easiest thing first....
    I've looked a fuses and not seen breaks at the extreme end of them. So now I check them with my trusty, old Rat Shack VOM...
    Glad you're back in the tunes, jasonkodat. A pencil eraser will clean the fuse ends and fuse clips up quite nicely...
    More later,
    Tour...
    Vox Copuli
