Polk monitor 7
vstarkwell
It's been quite awhile since I posted here on the Polk forum and after what transpired today I thought I would chime to a say hi and get an opinion.
I was speaking earlier, with a good buddy of mine and fellow CP member Carl (schwarcw), today about finally getting around to redoing my 7C's. We were discussing tweeter replacements, caps, costs etc;.
About an hour or so later I noticed on my local CL that there is a pair of 7A's for sale for a little more then the cost of a pair RDO-194's. I heard back from the seller and it turns out we know each other from previous audio selling/purchasing. He just moved and said they are still wrapped up and he will get back to me with pics so I can determine if they indeed have the peerless tweets.
My thought is instead of spending close to $100 on new tweeters why not just grab the 7A's with hopefully would be peerless tweets.
My questions are thus, would what I have listed below also be correct if I wind up getting the 7A's?
33uF 400V
12uF 200VDC
2.0 ohm (resistors)
Another question would 33uF 450VDC as opposed to 33uF 400V be okay?
TIA
33uF 400V
12uF 200VDC
2.0 ohm (resistors)
TIA
Monitor 7C's With Tubes
I have 7b's with Peerless tweeters that I like a lot. When I rebuilt the crossovers I used a 34uf cap instead of the 33. Easier to find and with the tighter tolerances it is within spec of the originals. I just rebuilt a pair of 7c's for my brother using the 33uf, 12uf, 2 ohm resistor and replaced the polyswitch with a. 5 ohm resistor. He was on a tight budget so we used Dayton caps and Mills resistors, all from Parts Express. With shipping he was at $59.
Thanks for the reply, you mentioned replacing the polyswitch with a. 5 ohm resistor. Is this necessary? if so what does it add to the overall sound?Monitor 7C's With Tubes
