If I have amp schematics can anyone look and tell if it is common ground?
Hello all
Have a Kenwood KM-208 that I need to see if it is common ground. Talked to Kenwood but they don't know, found block diagram online but can't read it properly.
If I posted the schematics would anyone be able to decipher it for me?
  • codycatalist
    codycatalist Posts: 2,661
    Thanks!
  • FTGV
    FTGV Posts: 3,650
    Yes it is common ground.
  • codycatalist
    You da real MVP @FTGV
  • xsmi
    xsmi Posts: 1,804
    FGTV, how'd you know? I'm just curious. I love to learn.
    2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • FTGV
    FTGV Posts: 3,650
    edited June 2016
    xsmi wrote: »
    Looking at the schematic for this amp,if you follow the negative speaker outputs backward.You can see both are connected to ground internally,so are "common" ground.
    Some amplifiers( ie.Adcom 5802) have their negative terminals connected to internal ground but channel grounds are isolated from each other.They are usually connected together and to chassis safety ground through a small amount of resistance.(10-20 ohm resistors).Amps so configured can be made common ground by strapping the negative terminals.
    The negative speaker terminals of a non common ground amplifier will have no internal connection to ground.These bridged /balanced amplifiers cannot have their negative terminals strapped together.
  • xsmi
    xsmi Posts: 1,804
    Awesome. Thank you.
