If I have amp schematics can anyone look and tell if it is common ground?
codycatalist
Hello all
Have a Kenwood KM-208 that I need to see if it is common ground. Talked to Kenwood but they don't know, found block diagram online but can't read it properly.
If I posted the schematics would anyone be able to decipher it for me?
Sure
Thanks!Just a dude doing dude-ly things
"Audiophiles are the male equivalent of cat ladies." - Audiokarma Member -
Yes it is common ground.
You da real MVP @FTGVJust a dude doing dude-ly things
FGTV, how'd you know? I'm just curious. I love to learn.2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-19L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
Looking at the schematic for this amp,if you follow the negative speaker outputs backward.You can see both are connected to ground internally,so are "common" ground.FGTV, how'd you know? I'm just curious. I love to learn.
Some amplifiers( ie.Adcom 5802) have their negative terminals connected to internal ground but channel grounds are isolated from each other.They are usually connected together and to chassis safety ground through a small amount of resistance.(10-20 ohm resistors).Amps so configured can be made common ground by strapping the negative terminals.
The negative speaker terminals of a non common ground amplifier will have no internal connection to ground.These bridged /balanced amplifiers cannot have their negative terminals strapped together. -
Awesome. Thank you.2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-19L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
