Just received a pair of REL T5 subs
I bought these T5 subs for use with a pair of KEF LS50 bookshelves. Although not dialed in completely I'm blown away by the sounds coming from these little 1 foot cubes. How do you get that much quality sound out of a little 8" driver with 125 watts? I thought they seemed expensive for for what they are, that is until I hooked them up! I'm very impressed so far.
Vinyl, the final frontier...
  • [Deleted User]
    [Deleted User] Posts: 10,716
    interesting as I am in the market for a small sub. How big is your room?
    How u like the Kef's? :*
  • madmax
    madmax Posts: 12,434
    edited June 2016
    I like the KEFs a lot! I am using a Schiit Ragnarok amp with it. A reviewer in Stereophile claimed the combo of the KEFs with the Rag was the best sound he has heard in the 21st century.
    The romm is approximately 18 x 16' with vaulted ceiling. At first I hooked up just one T5 and it provided plenty of bass with no problem. Then I added the second one and that is where the sound magic really took over. Stereo subs are the way to go, at least in this application.
    I noticed audioadvisor has the T5 for $599 each now that the T5i has been released for $749 each, the original price of the T5.
  • [Deleted User]
    "A reviewer in Stereophile claimed the combo of the KEFs with the Rag was the best sound he has heard in the 21st century." :o
    thanks for the info! I'll check out AA :)
  • madmax
    Oops, that was musicdirect for $599. http://www.musicdirect.com/p-13261-rel-t-5-subwoofer.aspx
  • madmax
    These from Goldenear (Sandy Gross company, ex Polk guru) looked interesting also. http://www.goldenear.com/products/forcefield-subwoofers
  • [Deleted User]
    Thanks! Choices!! :p
  • madmax
    Using the passive radiator like the Golden Ear is something REL does on a lot of their line. Over the years though, when I ask about audiophile music subs, REL is always the first mention from other audiophiles.
  • mikeyb128
    mikeyb128 Posts: 2,885
    I was torn for the longest time between a couple rel subs or some small sealed svs subs. I would love to try a pair of T5's in my system one day. Very nice subs, but haven't heard any in person. They are Priced way to high up here in Canada.
    2 channel:
    Theater:
    txcoastal1 Posts: 13,132
    I don't get why UK products are expensive in CA
    tonyb Posts: 32,906
    madmax wrote: »
    Yes Sir, Rel has always made musical subs, which also makes them easier to integrate with your speakers than HT based subs. Dual subs for music is the way to go imho, good choice there.
  • madmax
    tonyb wrote: »
    madmax wrote: »
    I tried the single sub first. It was OK but adding the second one is where the sound really came together. With the single I was able to tell there was a sub hooked up but the bass became fully integrated with the mains when I added the second one. More difference than I would have thought by adding the second one.
  • FTGV
    FTGV Posts: 3,649
    The LS50 and T5's should be a great combo once you get them dialed in.
  • kharp1
    kharp1 Posts: 3,453
    madmax wrote: »
    I'm interested in the GoldenEar as well. Size is good for me and thinking they may be more musical than some just because of who they're from.
  • kharp1
    kharp1 Posts: 3,453
    Got to audition a T5 this past weekend. Impressive little sub. Would have like to hear the T9 with the passive radiator but ran out of time.
  • Joey_V
    Joey_V Posts: 8,521
    You using speakon inputs?
    Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound
  • NotaSuv
    NotaSuv Posts: 3,815
    Love the REL subs, using a Strata III with my Mirage M3si speakers = seamless sound
