Woodworking question
Just an amateur woodworker with a few basic tools, and I'm planning to build a simple bench, similar to this:
The legs and frame will be assembled with dowels and glued, but I'm undecided as to how I should attach the boards on the top. Suggestions?
    pitdogg2 Posts: 27,055
    Screws and wood plugs. If you do not want them seen
  • mrbiron
    mrbiron Posts: 5,721
    What are you using for the top? Indoor or outdoor? Trex, azek, wood, PT...?
    Azek has a great decking screw with plugs that work/look nice.
    F1nut Posts: 51,778
    Blind dowels and wood glue. If the design doesn't call for a center support board running front to back, you might want to consider adding one.
  • mdaudioguy
    mdaudioguy Posts: 5,165
    That's what I'll do - thanks! Yes, I definitely planned for a center support.
  • deucekazoo
    deucekazoo Posts: 146
    Check out the Kreg pocket hole jig. I have used it a lot and it works great.
    Polk S10, S8, S4
    Polk RT8
    Polk Monitor 7s
    Working on getting SDAs
  • decal
    decal Posts: 3,205
    deucekazoo wrote: »
    Ditto
  • Upstatemax
    Upstatemax Posts: 2,737
    deucekazoo wrote: »
    This.
    It will save you A LOT of time and effort when used effectively.
  • mdaudioguy
    Here's my (un)finished project. Everything went well.
  • vcwatkins
    vcwatkins Posts: 1,993
    Beautiful.
  • scubalab
    scubalab Posts: 3,105
  • Jstas
    Jstas Posts: 14,985
    Pretty!
    Expert Moron Extraordinaire
  • deucekazoo
    Looks very good! You going natural or are you going to kill it with stain?
    Polk S10, S8, S4
    Polk RT8
    Polk Monitor 7s
    msg Posts: 10,452
    that looks fantastic! better than the model photo you posted.
    Would you mind posting some details on your build? I mess around with building stuff periodically, but nothing this nice yet. Curious as to lumber type/dimensions/source, etc., and whether purchased in this finish, or whether you had to modify/clean it up. Very nice work.
    F1nut Posts: 51,778
    Ed, that looks great!
  • mdaudioguy
    Thanks guys. I appreciate the compliments.
    As far as finish goes, we're leaning toward natural with a clear coat. Here's the deal. I made this for my son and his (now) wife for their wedding. The bench served as a guest book of sorts, and all the guests wrote messages and signed the top surface. Everybody was pleased with the result. I found some Indian ink pens to use for this, which I think shouldn't fade, but stain is out of the question for the seat. We've tossed around the idea of staining the legs and frame for a two-tone look, but I'm not sure. I'll probably stain a few scraps to see what it looks like.
    msg - I used 1x8 poplar boards and ripped them to produce 2-1/2" boards. It's a 4-foot bench and is about 17" high and 16" deep.
    txcoastal1 Posts: 13,513
    What a wonderful idea and congrats to your son and his new wife
    Nice job
    F1nut Posts: 51,778
    Keep in mind there will likely be a nice upholstered cushion on that bench in the not too distant future.
  • Upstatemax
    I would look into this stuff for a clear finish:
    https://www.amazon.com/gp/product/B001OBT0XM/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
    I've used it a couple of times and it has worked really well.
    F1nut Posts: 51,778
    No offense, but wax is an extremely poor finish. Actually, it's really not a finish, it's a polish.
  • Upstatemax
    I've used it a few times, with very good results. I like the idea that it's easy to apply, very easily repaired and you have a lot of control over the final look.
    If he built a kitchen table, wax would never cross my mind. But for a piece like this, I don't see any reason it should be overlooked.
