Woodworking question
mdaudioguy
Just an amateur woodworker with a few basic tools, and I'm planning to build a simple bench, similar to this:
The legs and frame will be assembled with dowels and glued, but I'm undecided as to how I should attach the boards on the top. Suggestions?
Screws and wood plugs. If you do not want them seen
What are you using for the top? Indoor or outdoor? Trex, azek, wood, PT...?
Azek has a great decking screw with plugs that work/look nice.Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
Blind dowels and wood glue. If the design doesn't call for a center support board running front to back, you might want to consider adding one.
That's what I'll do - thanks! Yes, I definitely planned for a center support.Blind dowels and wood glue. If the design doesn't call for a center support board running front to back, you might want to consider adding one. -
Check out the Kreg pocket hole jig. I have used it a lot and it works great.Polk S10, S8, S4
Polk RT8
Polk Monitor 7s
Working on getting SDAs -
deucekazoo wrote: »Check out the Kreg pocket hole jig. I have used it a lot and it works great.
DittoIf you can't hear a difference, don't waste your money. -
This.
It will save you A LOT of time and effort when used effectively. -
Beautiful.Beach Audio: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
Town Porch: WiiM Pro Plus * Sunfire Sig II * Canare 4S11 * Magnepan 1.6 * Dectet -
Very nice!!
Pretty!Expert Moron Extraordinaire
Looks very good! You going natural or are you going to kill it with stain?Polk S10, S8, S4
Polk RT8
Polk Monitor 7s
that looks fantastic! better than the model photo you posted.
Would you mind posting some details on your build? I mess around with building stuff periodically, but nothing this nice yet. Curious as to lumber type/dimensions/source, etc., and whether purchased in this finish, or whether you had to modify/clean it up. Very nice work.I disabled signatures. -
Ed, that looks great!
Thanks guys. I appreciate the compliments.
As far as finish goes, we're leaning toward natural with a clear coat. Here's the deal. I made this for my son and his (now) wife for their wedding. The bench served as a guest book of sorts, and all the guests wrote messages and signed the top surface. Everybody was pleased with the result. I found some Indian ink pens to use for this, which I think shouldn't fade, but stain is out of the question for the seat. We've tossed around the idea of staining the legs and frame for a two-tone look, but I'm not sure. I'll probably stain a few scraps to see what it looks like.
msg - I used 1x8 poplar boards and ripped them to produce 2-1/2" boards. It's a 4-foot bench and is about 17" high and 16" deep. -
What a wonderful idea and congrats to your son and his new wife
Nice job2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Keep in mind there will likely be a nice upholstered cushion on that bench in the not too distant future. -
I would look into this stuff for a clear finish:
https://www.amazon.com/gp/product/B001OBT0XM/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
I've used it a couple of times and it has worked really well.
No offense, but wax is an extremely poor finish. Actually, it's really not a finish, it's a polish.
I've used it a few times, with very good results. I like the idea that it's easy to apply, very easily repaired and you have a lot of control over the final look.
If he built a kitchen table, wax would never cross my mind. But for a piece like this, I don't see any reason it should be overlooked.
