What is the best way to wire two MM1240 SVC subs to a PA D1000.1?
rsalinasg
Best Answer
Ah, then not much choice, one sub on each channel.
Answers
Hello,
If you wire each of the two subs in parallel the load will be 2 ohms, your amplifier can produce 800watts into a 2 ohm load for left and right channels.
The sub's owner's manual will show how to wire the voice coils in parallel.
Regards, Ken -
My subs are single voice coil.
Thanks.
