Home Theater Build/Remodel
  • scubalab
    scubalab Posts: 3,105
    edited April 2016
    hochpt21 wrote: »
    Cool, I'm glad you have it thought out. And I really hope it sounds good, because I think the cutouts are awesome.
    Fingers crossed Paul... I hope it sounds good too.
    What I SHOULD have done was built speaker shelves that pull all the way out of those recesses and a roll-top door to close behind the speakers! Oooh, motorized too - on a 12v trigger. I can do it...!
  • scubalab
    Final coat of mud is done! Just need to sponge it (trying something new instead of sanding... Wet sponge), paint, make trim, install new screen and move all the equipment to its new home!
    EndersShadow Posts: 17,743
    So a couple comments we haven't addressed yet that I'm aware of..
    1. Are you gonna paint the woodworking too or just the drywall?
    2. Acoustic panels... how many, where are we putting them? The DOOR assuming its the same glass one from other pictures could sure use some sort of acoustic panel to help with reflections off the glass......
    Otherwise like I've been saying I'm jealous of you....
  • scubalab
    Dan - We debated taking the pine down in the room, but decided to keep it at this point. So, at this point, just the drywall will be painted. As for the door, yes, it is a glass door. The plan is to get a thick curtain that can be pulled across it to keep light from the adjacent foyer and kitchen out of the room. Haven't given much thought to acoustic panels in the room when done, but may be worth considering.
    scubalab wrote: »
    If I could make a suggestion... go ahead and to the curtain..... but for SERIOUS listening time and movie time, build a acoustic treatment the size of the door and put it on a set of curtain rods so you can set it up on hooks on either side of the doorway to block it off.
    Also "try" to do panels on your first and second reflection point.... IIRC you cant do anything hanging from the ceiling given the height, but at least try to do the first and second reflection points if possible...
    Since your a DIY kinda guy, talk to Ryan ( @ZLTFUL ) about the guy on AVS he had help make movie poster pictures so he could get them printed on fabric for his treatments.
    You could pick some of your fav movie posters to get put on the fabric, or even some team logo's so they look more like really nice canvas posters than treatments....
  • vmaxer
    vmaxer Posts: 5,121
    Great job, and awesome to have the helper.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • scubalab
    edited May 2016
    Getting closer!! Spent ALL day yesterday and into the wee hours of Sunday morning sanding, painting, re-installing trim, lights, etc., and finally moved the equipment to its new home. This morning, I cut, painted, and installed the trim around the built-ins, assembled and hung the new screen, and just now sat down to relax. Spent about 16 hours yesterday and 4 hours today.
    Here's how it looks now. Still have to finish around the door, replace/repair some of the pine wainscoting, replace the AC unit and baseboard with a new split heat pump, replace the carpet, get some new furniture, and make the built-in subs.
    Also need to build a more permanent door cover to replace the styrofoam panel in the left of the photo above.
    Post edited by scubalab on
  • chumlie
    chumlie Posts: 8,658
    Nice work !!! Enjoy.
  • scubalab
    edited May 2016
    The colors are Penn State shades (we do live in Happy Valley) - dark navy blue on the screen wall and grey on the left wall and ceiling.
    Hope to run the calibration later and Christen the new setup with a nice family movie tonight. We're thinking How to Train Your Dragon. :)
  • lightman1
    lightman1 Posts: 10,797
    Nice work Al! Now you can enjoy the fruits of your labor.
  • mrbiron
    mrbiron Posts: 5,721
    Now that you have the gear installed, I'm really diggin that "rack" you've constructed.
    Kudos!
  • polk500
    polk500 Posts: 1,171
    Ya done good, I like the colours especially how the light colour trim makes the recesses and the rack stand out.
    Enjoy
  • hochpt21
    hochpt21 Posts: 5,423
    Looks great Sir!
  • mikeyb128
    mikeyb128 Posts: 2,885
    Love that equipment rack, and I like the wood paneling as well. Very cozy. I saw an svs ultra cylinder once and almost fainted at how girthy it was lol
    2 channel:
    Theater:
  • scubalab
    Thanks for all the kind words everyone!
    Well, I had a chance to run the Audyssey Multi EQ calibration on the Marantz. Let me just say WOW! Boy did it really clean things up with the surround sound. It's truly a pleasure to really hear things that we never noticed before. I'm not saying that the old setup was a slouch by any means. My Anthem was a fantastic AVR and the Rotel I I had running 5/7 channels was great. BUT, the Marantz and the B&K Reference amp are a great pair - with all speakers in their proper positions and the correction done, it really smoothed things out. Even at low volumes, the sound is spot on. My daughter and I kept turning around looking for someone knocking on the door in the other room at one point!
    A word on the front L/R speakers in the recesses...
    The sound is definitely a bit different, but I have to say that it's not 'bad' to my ears. The first thing I listened to was some music streamed from Spotify. The sound was very full and had some pretty distinct/punchy bass. I actually thought the sub was turned up a bit and the center channel was on. It was in fact, just the two front speakers. I was surprised the other speakers were not 'on'... Once I ran the Audyssey, got things fine tuned, and ran the full surround, things actually sound fine to me. I may play a little with fine tuning further (might try Dan's suggestion plugging the rear ports and re-calibrating). I know it's not perfect, but to us, it sounds great, and the built-ins really opened up the tight space in the front of the room.
    We're really excited to watch a full movie this weekend!
    I'll keep everyone updated on further progress. I'm looking forward to completing it and eventually building me some DIY SUBS!!
    Google VBSS and look at the AVS thread.... Might be able to make that work for you....
  • Jaybeez
    Jaybeez Posts: 748
    Great build. A dedicated theater room is definitely on my bucket list.
    I'm sure you and your family will enjoy yours for years to come.
    2 Channel "Polk" Room:
    Marantz PM8004 Integrated
    Marantz SA8004 SACD Player
    WiiM Mini
    Polk 7B with RDO198s
  • kevhed72
    kevhed72 Posts: 5,191
    Very nice....especially given the limited space. I wish I could wood work like that!
    msg Posts: 10,562
    edited February 2019
    Al, just skimmed this thread to have a closer look at your Flexi build, and have to say after seeing the whole thing, I feel like even *I* need a beer after all that work!
    Fantastic job here, man. And love the planning and love the option for system access from behind.
    pitdogg2 Posts: 27,624
    Just wait.... he’s on V2.0 now....
  • scubalab
    Thanks guys! This is actually an old thread. However, with what we recently continued in the theater, I was going to revive it anyway!
    About a month ago, we ordered new furniture (the BAC - Big A** Couch as my wife calls it). That led to ordering new carpeting. Well, since the bar adjoins the theater, we also had to do new flooring in there too. And then it snowballed. We ripped the bar out, removed the tongue & groove cherry planking on the walls, ripped down some drywall and were down to studs in 100% of the bar and 50% of the theater. That led to new heat, new lights in the bar, rerouted plumbing and electric, new receptacles throughout, modified headers, etc. it’s been a month of work every weekend and some evenings during the week. Finally we were ready for the carpet mid last week. It was installed yesterday morning. I finished the trim yesterday afternoon.
    We repainted everything and went with the dark blue on the front wall up across the ceiling and down the back wall. Now just the side walls and the bar are grey.
    The theater is now done except for the back wall, the grill on the left subwoofer, and the decorating. The bar will get finished in a month or so. Right now, we’re in need of a break (both physically and financially)!
    Here’s a couple pictures along the way.
    Old bar (pano of back wall)
    Down to studs in the bar
    New drywall lights and flooring in the bar
    New carpet, doors, paint and trim in the theater
    Finished floor, walls, lights, trim, and paint in the bar
    Hey your outlets don’t look lined up :wink:
  • scubalab
    scubalab wrote: »
    Shut up Dan!
    Hey I coulda done worse :wink:
