Dynaco 350 speakers
soundfreak1
Anyone know these? Very little on the net. Would love some info if you have any. Thanks
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Isn't the model "A350"? If you search for that (and spell "Dynaco" correctly) you'll find a fair amount of stuff, like this: http://audiokarma.org/forums/index.php?threads/dynaco-a-350-speakers.317981/
Not "real" Dynaco, but based on the images I see on Google, they look like they might be decent. Nice Scandinavian dome tweeter (same one used in early Boston Acoustics designs -- I forget which OEM, maybe ScanSpeak?) and what looks like the classic 4" pincushion frame CTS midrange driver (a very nice driver, a version of which incidentally was used by Polk in the "Monitor 9" in the early/mid 1970s).
Might be worth checking out if in good shape and cheap, I'd opine.
http://audiokarma.org/forums/index.php?threads/dynaco-3-ways-on-kc-cl.202814/ -
These are the 350's
Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
^^ I think that's the original Seas tweeter ^^ if I'm not mistaken - same one on the early Boston Acoustics as you pointed out.VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
Appear to have a top firing tweeters. Might add some interesting reflected/spatial quality to the sound.Home Theater/2 Channel:
dhsspeakerservice.com/ -
plus they look cool
They look cool as **** but.....Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Have to say they are beautiful speakersRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
If price is good, get them.
I heard smaller dynaco and they were great sounding speakers.
huh == sorry, what I found appears to be way off (though maybe temporally related).
The true A350s certainly look... intriguing. Worth a look -- or, more to the point, a listen, I'd think.
Are you imbibing already, Mr H?
just Rwandan tea (with milk & sweetener), so far...
"Rwandan tea" is that what they call it now? Doesn't the milk make it hard to light?Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
soundfreak1 wrote: »"Rwandan tea" is that what they call it now? Doesn't the milk make it hard to light?
Naah, real tea. The dried (or,in the case of 'black' tea, fermented) leaves of the bush, Camellia sinensis, steeped in hot (in the case of black tea, boiling) water to extract a variety of organic compounds -- caffeine, tannins, organic acids and lots of other things.
http://www.uptontea.com/store/item.asp?from=catalog.asp&itemID=TK12&begin=0&parent=Teas>Black>Africa&category=Rwanda&sortMethod=0&categoryID=264
Goes great with good music, too, just like that other kind of tea -- or so I've heard...
Great story. Don't believe any of it!Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
aww, go buy the danged speakers!
LOLMain Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
